Old 06-02-02, 11:16   #1 (permalink)
Come on! Fhqwhgads!!
Jngrbrdman's Avatar
Jngrbrdman is offline
Contact: Send a message via AIM to Jngrbrdman Send a message via Yahoo to Jngrbrdman
Painting calipers
I know I've seen threads on this before. I'm having a hard time finding them though. The first thing I'm going to do in my new garage is to paint my calipers and I don't want to screw it up. If anyone knows where to find those threads then that would be helpful. Or even if you want to offer some advice. I am really interested in knowing how to mask them off properly and not make it look like a cheap job. I've got nothing but time on Saturdays and Sundays so I'm ok with taking my time on it. I want it to look real good. Also if you have any suggestions for color. Its just a white car with silver rims. I was thinking about going just gloss black but that is subject to change.
...it should be Encouraged!
Old 06-03-02, 01:46   #2 (permalink)
Krasse
NogaroS4Buffer's Avatar
NogaroS4Buffer is offline
Contact: Send a message via AIM to NogaroS4Buffer
http://www.autopia-carport.com/forum...=audi+calipers
Some info that thread.
http://forums.audiworld.com/s4/msgs/287878.phtml
Audiworld writeup. There may be some better wriiteups at audiworld, you should check it out.
http://forums.audiworld.com/s4/msgs/569862.phtml
Another.
Old 06-03-02, 02:34   #3 (permalink)
Jngrbrdman's Avatar
Those were very helpful links. Thanks!
Do you guys think that painting them white would be a mistake? How fast do you think they would go from "Boy, that is sure a nice looking setup you have there" to "Damn boy! Wash your calipers!" I'd like to do them white but if they are going to get dirty 30 minutes after I wash them then forget it. I'll just go black. Right now they are sort of a goldish color it looks like. Anything will be an improvement. Maybe David can make some small 'AUTOPIA' stickers for calipers while he is getting the gear together. I'd proudly put it on my car. I think it look cool. lol
Old 06-05-02, 04:43   #4 (permalink)
Trainee
v85097's Avatar
v85097 is offline
If you plan on painting them "off of" the car using a kit like G2 or Foliatech then masking would not be an issue for you. If you plan on painting them in place by spraying then your whole approach would have to be different. I would say if you like white then go for it, you might have good luck with it depending on your wheel cleaning frequency, driving\braking habits etc...
I did mine metallic silver for uniformity between the wheel and rotor instead of black or red after wondering about the dust issue as well but I like it so far and all three components pretty much dust up evenly. I think white if nothing else could prove to be a challenge in keeping them looking white or not be an issue if you clean your wheels every three or four days, good luck
wallie
Old 06-05-02, 01:12   #5 (permalink)
The Red Baron
Mugenman is offline
Ive seen white calipers, they look dope, but they will look dirty after a while, you will need to scrub them often......but that´s no threat to an autopian!!!
Whatever you do, you can do it in the car, but remove the brake pad, it is simple, it is done by loosening the lower caliper bolt, then you flip the caliper upwards, and remove the pad.....then use some newspapers to cover up the brake disc and suspension, and use some msasking tape for the brake lines, fittings, bolts, etc....
Old 06-05-02, 01:30   #6 (permalink)
Jngrbrdman's Avatar
What problems can happen if I don't take the brake pad off? Can't I just mask it? I'm pretty handy under the hood but brakes and suspension always make me nervous. I worry that I won't be able to put them back together.
Old 06-05-02, 01:57   #7 (permalink)
Cya, & take the care eh?
4DSC's Avatar
4DSC is offline
It's been my personal experience that messing around with disc brakes are easier than a lot of jobs under the hood. I hate drum brakes though.
Tip: make sure when you re-assemble you either put back the anti-squeal pads between the pad and piston/caliper or goop more anti-squeal stuff on there first.
Brian
Old 06-05-02, 04:08   #8 (permalink)
The Red Baron
Mugenman is offline
Men, it´s eaaaaaasy!
Only one bolt, and you slide the caliper upwards, then, the brake pads come off, that´s it! Once you remove the brake pads, you can also remove a small metal piece that goes in the pad groove for further oem look!
This is what mines look like, it has chipped while installing my 14" steelies for the track........it sucks.....
Old 06-05-02, 04:11   #9 (permalink)
Jngrbrdman's Avatar
On a scale of 1 to 10 (one being an intake install and 10 being a turbo install) how would you rate changing your rotors and upgrading your calipers and pads? I was thinking of changing the rotors first and then getting the calipers changed. I love the look of slotted rotors and was looking for good deals. I've found a few places that look good.
Old 06-05-02, 05:40   #10 (permalink)
I'm back.
Antonio Wright's Avatar
Antonio Wright is offline
Contact: Send a message via AIM to Antonio Wright
It took me and a friend less then a hour and a half to install my 13inch bear brakes. That included draing fluid, changing lines etc..
-Antonio
04.5 Passat GLS 1.8T - Grey Leatherette - 5 spd Manual - TechTonics Exhaust - FK Coilovers - Wetterauer 1.0 Bar chip - H&R Wheel Spacers
Old 06-05-02, 05:52   #11 (permalink)
The Red Baron
Mugenman is offline
I´d say its a 5........the most difficult part could be bleeding the brake lines, makng sure no air stays on the lines......
the rest, is only 2 phillip screws, two 12mm bolts, and 2 17mm bolts......thats it period!
Old 06-05-02, 05:54   #12 (permalink)
4DSC's Avatar
4DSC is offline
If you're getting bigger calipers or bigger rotors, first make sure your wheels are big enough or spaced right to fit them if you haven't done so already.
Brian
