Originally Posted by at24
..So I had some damage repaired on my car about a month ago and my paint clearly does not match. From what I've read on other forums, my paint (Obsidian Black Pearl by Subaru) is one of the harder paint colors to match. So my dilemma is that my newer paint has a noticeable green tint to it...
Welcome to Autopia!
Sorry to hear about your Subie.
Sounds like the shop messed up. While it *is* very hard to match pearls, when you get a green/blue/etc. difference it says "bad paint match job" to me (and it also says bad quality control because if *you* see it, they did too but they thought they could get away with it).
I've run into this countless times with silver...e.g., Mazda silver from a lot of paint manufacturers has the wrong degree of blue to it. Unfortunately, between different paint manufacturers, paints with the same code are still *different*. You can pick four different paint manufacturers and you'll get four different-looking paints that oughta all look identical.
A good shop will know which brand to start with, and will then tweak that to ensure a good match.
I'd either see if the shop can make it right (may be siply beyond their abilities) or find a shop that'll say "yep, they messed it up by...[good explanation]...we can redo that properly".
