Old 08-24-08, 06:46   #1 (permalink)
ernman is offline
Spark Plug Question
I have a 2004 Outback, and it is time to change the plugs. I did a quick search and the price ranges from $3.00 to $10.00. What would I gain with the $10.00 plugs?
Old 08-24-08, 06:56   #2 (permalink)
dazzerjp is offline
Re: Spark Plug Question
if its iridium plugs, then you get durability.
Old 08-25-08, 12:25   #3 (permalink)
Heathenbrewing is offline
$10 is most likely for iridium plugs. I copied and pasted the below from my posting on another forum. Copper vs. plat. vs. iridium is a touchy subject, but below is my OPINION on them:
Some people swear by iridium plugs, claiming more HP and better MPGs, but truth be told, it is all hype and marketing. For me, I always look for independent testing and/or data analysis, not a website that is in the business of selling plugs, or any of the billion of forums that have all kinds of opinion, but no solid fact to back them up.
Electrical conductivity of Platinum: 94.34 1/mohm-cm
Electrical conductivity of Iridium: 188.679 1/mohm-cm
Electrical conductivity of Copper: 595.8 1/mohm-cm
Copper is the most conductive metal next to silver. If you are into power, spark energy, or conductivity, and heat transfer are two critical features to make peak HP. Copper conducts electricity and heat over 5 times better than platinum and almost 3 times better than iridium, but does not have the life span of either. Do you really need to get 100,000 miles out of a set of spark plugs? Would you really want to leave plugs in a motor for that long anyway? I wont pretend to speak for anyone else, but I think you know what my answer would be.
Copper corrodes faster than PL or IR, so they would require more maintenance. This is not an issue for me as I replace them often, but the average US car owner is very negligent when it comes to maintenance. This is partially the reason why some cars come from the factory with PL or IR plugs IMO.
I would never clean plugs because if I am going to spend the time to pull 'em (15 minutes), I might as well drop in new ones. $8 a year (I pay $2/ea) you and have damn near perfect plugs. $16 a year and you would have perfect plugs.
If you are running a stock motor, copper is the way to go IMO.
Expensive spark plugs do not increase your vehicles performance and power.
Regular replacement does.
New plugs will only free up whatever power you lost due to running plugs too long. They do not and can not free up power that is not already there. While using a premium platinum plug will extend the service life of the plug, it will not in any way increase performance or power either, unless your plugs were holding you back for whatever reason to begin with.
The only realistic advantage of any premium plug is a decrease in gap erosion. Gap erosion occurs when the spark burns away small bits of the electrode and ground contact during combustion. Over time a properly gapped plug will slightly increase its gap but not generally enough to cause any problems if the plugs are replaced in accordance with the manufacturers suggested maintenance routine. So the extra dollars you pay for these kinds of plugs are truly wasted if you are a responsible vehicle owner who changes the plugs regularly like you should.
Keep your engine and your wallet happy by installing properly gapped, stock or quality replacement spark plugs at the required intervals.
Your choice of plug will depend on how often you want to replace them.
I run NGK copper exclusively. Since I put in new ones yearly, I have no need for iridium or platnium as they are for longevity only and do not increase horsepower or MPG regardless of what sooo many others want to believe. IMO, those who say otherwise are just trying to justify the extra money they spent on fancier plugs.
If any of you are REALLY interested in documented and independent testing data, and you have $14 to spare, go to the SAE site and order paper number 2006-01-0224, 'The Effect of Sparkplug Design on Initial Flame Kernel Development and Sparkplug Performance'.
Old 08-25-08, 03:37   #4 (permalink)
paul34 is offline
If you have no pressing special needs (such as running some sort of dedicated, unstreetable drag car or such), then get some iridium plugs, preferably Denso. There's a reason many OEMs use Denso iridium on their motors from the factory - its tough to beat them for durability, and dependable performance spark after spark.
ONR = Optimum No Rinse
Old 08-26-08, 04:55   #5 (permalink)
Resident gun nut
BoostedMopar's Avatar
BoostedMopar is offline
If your car doesn't run PLATINUM plugs from the factory DO NOT use them. I know we are talking Iridium and you should be fine with those.
DüRTy MicROFiBüRz CReW
Member 001
Old 08-26-08, 06:21   #6 (permalink)
Yal
Yal is offline
Check your factory manual and run the plugs it mentions.
Old 08-26-08, 06:36   #7 (permalink)
I'm a shiner
Gears's Avatar
Gears is offline
On the new Subarus the Turbos get Iridium and the regular engines call for Platinum.
Old 09-16-08, 08:34   #8 (permalink)
spike_africa's Avatar
spike_africa is offline
Like he said dont waste your money on the hype a plug isnt going to make you faster. I run cheap NGK's in my sprayed mustang.
2002 GT Mustang 5speed
-sprayed,drag radials,powershifted every day
Old 09-16-08, 11:07   #9 (permalink)
miahman98's Avatar
miahman98 is offline
I would recommend you get a good set of wires instead expensive plugs. A good quality and well made set of wires will help keep you car running tip top for years to come. Go with the middle of the road plugs just so you don’t have to question your decision later.
Old 10-10-08, 01:14   #10 (permalink)
ofl0926 is offline
+1... remember that plugs and wires will produce an even spark and good combustion
Old 10-10-08, 01:51   #11 (permalink)
longdx is offline
Agreed that many "performance" claims of many plugs are just hype. I would recommend using the factory replacement plugs suitable for your application. A good rule of thumb, is to use Japanese specific plugs for imports, and American (Autolight, Motorcraft, etc) for domestics. Remember, Iridium helps in preventing corrosion at the tip and extends usable life of the plug (over 35k normal driving) whereas copper will corrode quicker but will still last @30k mileage.
I made the mistake of putting NKG iridium plugs in a domestic application , and the vehicle experienced driveability problems and threw some codes. Replaced with autolights (cheap factory OEM replacements) and all the problems went away.
Old 10-10-08, 03:14   #12 (permalink)
Concourse d'Elegance
stiffdogg06's Avatar
stiffdogg06 is offline
Contact: Send a message via AIM to stiffdogg06
I use NGK BRK7E gapped at .33" in my turboed civic.
I also suggest using what ever plugs your manual requires. They wouldn't put them in the car from the factory if they weren't made to run for a while.
Turbo D Club Member #000001
