'You may be able to squeeze a little more life out of the plastic before you paint it. Try using some of
this. Spray it on and let it sit for a while and then rinse it off with plain water just before the rubber cleaner dries. Maybe treat the faded plastic a couple of times to make sure it\'s clean and that all the \"dead\" plastic has been removed. After the plastic is dry, use some 303
Aerospace Protectant and see if the pieces still look faded. If they are too far gone painting may be the only choice, but this method will at least tell you if there is any life left in those pieces.'
