06-21-05, 02:47
| | 2 ∞ N Beyond
MCA is offline
Join Date: Oct 2004 Location: Dallas, TX Posts: 482 | Disappearing Tire Dressing... Hey folks,
I have read thru 20+ threads on tire dressings, but I still can't find what I'm looking for. Anyways...when it comes to tire care, I am a complete newbie. On the recommendation of several members I have been cleaning my car's tires with DP tire gel (old version) and using Zaino Z16 or Armor-All (water-based) as my dressing. I have zero problems with this combo. However, when I try the exact same method/combo on my wife's tires, the dressing literally disappears in an hour...it's like the tires "absorb" the dressing. I have to apply the dressing 3 times (sometimes 4) in order to get the "normal" low-sheen look on her tires. I am pretty positive that it is not product or application errors because it works to perfection on my tires. But as I mentioned before, tire care is one thing that completely confuses me so any info would be greatly appreciated. I definitely want to make sure that I am not damaging her tires.
Prep and Products Used:
DP Tire Gel Cleaner w/ Meg's Tire Brush
Zaino z16 or Armor-All w/ E1 Tire Swipe
My Tires: Michelin
Her Tires: Firestone
*NOTE* I am sorry about all the product specifics. I just would to make sure that my question is thorough.
Thanks,
MCA | |
06-21-05, 02:50
| | Mr. Anderson?
2wheelsx2 is offline
Join Date: Dec 2001 Location: Vancouver, BC, Canada Posts: 2,212 | How old are her tires? If they are older tires, it could be that it's being absorbed by the oxidized rubber. I have found the same on older cars. You can try using an APC of some sort, or a stronger cleaner/degreaser on the tires, and then drying them really well, and applying multiple coats until you get the look you want. After that, they should behave just like your tires.
Gary
MF is an acronym only safe to use on Autopia. "Dawn is for dishes, leave it in the kitchen." - Anthony Orosco | |
06-21-05, 02:55
Bill D is offline
Join Date: Jun 2003 Location: Birthplace of Speed Posts: 8,733 | I'd try a more tradtional liquid rubber cleaner. Mothers Rubber and Tire Cleaner before every dressing reapplication hasn't failed me yet on Pirelli, Michelin, Goodrich, and Goodyear. | |
06-21-05, 02:59
CutNAction is offline
Join Date: Sep 2004 Location: Coats, North Carolina Posts: 401 | I dont want to hijack your thread MCA, but your post caught my attention. I have pretty much the same problem. I have bigger tires (Grand Cherokee) and they are fairly new, but it seems like the very next day it looks as if nothing is on the tires anymore. I have tried multipe tire wets. I would like some information as well on this.
1999 Grand Cherokee Limited V8 4X4 and I'm loving the power!
06-21-05, 04:06
| | Just Obsessed
Alfisti is offline
Join Date: Jul 2004 Location: Perth, Western Australia Posts: 2,070 | How strong a cleaner do you use?
Maybe something like A2Z will strip off *all* contaminants, including oxidised rubber, giving it a virgin surface to start with.
__________________ Paul Marmarinos Flawless Prestige Car & Boat Detailing I was on Autopia before the stars were torn down. | |
06-21-05, 04:31
| | Canyoneer
John Styrnol is offline
Join Date: Nov 2003 Location: Layton, UT Posts: 4,191 | Try some of the Tropi-Care Tire/Rubber Dressing (New and Old), Tire Cleaner.
__________________ My Home Page
00 Explorer XLT
06-21-05, 04:40
| | Mr. Anderson?
Join Date: Dec 2001 Location: Vancouver, BC, Canada Posts: 2,212 | Quote: |
Originally Posted by Bill D I'd try a more tradtional liquid rubber cleaner. Mothers Rubber and Tire Cleaner before every dressing reapplication hasn't failed me yet on Pirelli, Michelin, Goodrich, and Goodyear. | I second the Mother's. Really good stuff, but still easy on the wheels. And it doesn't cause the tires to brown like some other cleaners do.
Gary
06-22-05, 03:08
marstang is offline
Join Date: Jul 2004 Location: York, PA Posts: 8 | I like using the Meguiars "Endurance" tire dressing. I'm currently using the high gloss version. It leaves a thin gel type coating on the tire. It doesn't seem to soak into the tire like other dressings I have used and I'm not experiencing the "sling" that several other members have complained about. The tires even keep their gloss after 1 or 2 rainstorms.
1998 Mercedes E320, Brilliant Silver
2000 Chrysler Town & Country, Slate Gray
1972 Ford Mustang Fastback, Lapis Blue with Silver Stripes
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is On | | | | All times are GMT -7. The time now is 05:21. | | | |
