Have you ever just looked at your car and thought that there has to be a better way of getting a fantastic finish? I have and after much thought and question asking I took the plunge and bought a PC 7424. After purchasing the Porter Cable 7424 orbital buffer I was not happy with the finish of my wife's 1997 Toyota 4Runner. It's dark blue and at the time I knew that I could make this finish look new again. I was feeling guilty for doing stupid things to the finish, so I take all the blame. There were still swirls and non-leveled scratches in the finish by the door handles and near the bottoms of the doors from feet banging the finish.
I used all Meguiar's products along with my PC 7424 and though the finish looked a bit better, I wanted more. I took the 4Runner to a friend of mine that has been detailing for over 15 years and had him take a look. He reviewed with me both the products I used to repair the finish and the Porter Cable orbital buffer as well. He has never used one, but he admits that for a quick polish job, you could not go wrong with this tool. However to achieve the results I wanted I was going to have to face my fears and get a rotary buffer. He made two suggestions to me about brands. The first was the old dependable Dewalt DW847 or they're DW849. Or the new kid on the block the Makita 9227c rotary buffer. After taking a look and feel of both tools, I settled on the Makita. Here's why:
The no load speed of the Makita is 0-3000 RPM. That gives the user a lot of control on how fast the head will spin on the surface, as well as the ability to control the heat build up. The speed control is right by the back handle and is a dial type control. Speeds varied from 1-6, each setting a bit faster then the last. I have only used it on 1-3 and three being about 1500 RPM and this with a high quality-leveling compound. Using 3M's Perfect-IT II I use about 1100-1250 RPM and only a few passes to remove the imperfections. Also when starting the buffer it does not hit max speed setting right away. It's clutched and so it's a gradual build up to the set max speed. Very nice in that it will not jump out of your hands and damage the surrounding finish!
The weight of the Makita is only 6.6 lbs. and that is much lighter then the Dewalt machines I looked at. Thus adding to the control and fatigue issues some people have to deal with.
Third was the sound of the Makita at full throttle. This thing is very quiet. I could not believe it and it was more so then even the Porter Cable machine! This is good if you are going to be doing buffing on a regular basis. Easy on the ears! My wife came outside to see if I had even started and was surprised to find me buffing away on her baby.
The products I've used on this vehicle are as follows:
1. 3M Perfect-IT II for the first several passes
2. Race Glaze Leveling compound to polish and level the finish.
3. Zaino Z-1, Z-2 for sealant protection.
All in all it took me four hours from start to finish with the Makita to get a deep, deep, wet shine that looks better then new. I am amazed at how easy it is to use this rotary buffer and get great results. My only trick is this: be thoughtful, careful and pay attention. If I can get this type of results my very first time using a rotary buffer, then I think any enthusiast of detailing can as well! Please follow the provided link below to check out this machine. Thanks for reading my review.
http://www.makita.com/product/tool.asp?MODEL=9227C
