05-21-08, 08:37
#61 (permalink)
| | 0 to 60 in one paycheck!
SuperBee364 is offline
Join Date: Apr 2007 Location: Salt Lake City, Utah Posts: 2,770 | Re: The Hype Surrounding DWG DWG is sealant based, so it would not bond properly over the top of RMG. Also, DWG and RMG are both glazes, so you probably wouldn't want to use two glazes. RMG is a glaze meant to be used before a carnauba based LSP, DWG is a glaze meant to be used before a sealant based LSP. | |
05-21-08, 09:09
#62 (permalink)
| | your speeding yellow
wascallyrabbit is offline
Join Date: May 2008 Location: NJ Posts: 128 | Re: The Hype Surrounding DWG good to know info. I'll hold off on the DWG for now till I finish off the RMG. | |
05-22-08, 11:21
#63 (permalink)
| | Dreamer
Bigpikle is offline
Join Date: Jun 2007 Location: England Posts: 382 | Re: The Hype Surrounding DWG well I finally managed a good clean and a layer of DWG followed by another layer of UPGP
Considering my car is a dark silver i was very impressed at the visible difference from the DWG application. Definitely glossier and wetter and look forward to tomorrow once the PGP is cured fully
Applied at speed 3 on the UDM with a red SFX finishing pad - went on really easy and buffed off even easier - LOVE this stuff and just exiled more bottles to the forthcoming sale
__________________ Your past is not your potential.... | |
05-22-08, 11:26
#64 (permalink)
Join Date: Apr 2007 Location: Salt Lake City, Utah Posts: 2,770 | Re: The Hype Surrounding DWG Good to hear, Bigpikle! I'm gonna do UPGP over DWG on the next car I do. | |
05-22-08, 11:53
#65 (permalink)
| | Dreamer
Bigpikle is offline
Join Date: Jun 2007 Location: England Posts: 382 | Re: The Hype Surrounding DWG did some by hand on the MG in the garage, but under the fluorescents on such a light colour its tough to see the impact...wait until some sun and a long drive
05-22-08, 12:01
#66 (permalink)
| | snowskate
snowskate is offline
Join Date: Sep 2006 Location: Boston Posts: 147 | Re: The Hype Surrounding DWG Is DWG compatible before CMW? Or would RMG be a better match? | |
05-22-08, 12:13
#67 (permalink)
| | Calm like a Bomb
EisenHulk is offline
Join Date: Mar 2008 Location: Lexington, KY Posts: 684 | Re: The Hype Surrounding DWG I finally have a sample of DWG thanks to Eliot Ness, who I finally got meet last night. Talk about GREAT guy to talk to.
I'll be trying the DWG soon...I bought the Ultima sampler today, so I'll be able to try it with UPGP.
05-22-08, 12:29
#68 (permalink)
Join Date: Apr 2007 Location: Salt Lake City, Utah Posts: 2,770 | Re: The Hype Surrounding DWG Quote:
Originally Posted by snowskate Is DWG compatible before CMW? Or would RMG be a better match? | You would want to use RMG before CMW, as CMW is carnauba based. | |
05-22-08, 08:10
#69 (permalink)
Bob D. is offline
Join Date: May 2003 Location: Chicago Posts: 3 | Re: The Hype Surrounding DWG Quote:
Originally Posted by SuperBee364 1. I can't answer this one, as I haven't tried that combo yet. It sounds like a real winner, though.
2. I think that Opti-Seal gives a pretty comparable look to UPGP. I really do like UPGP better, though, as it has among the best environmental protection of any of the sealants.
3. You would get better durability from the DWG (and any sealants you then put on top of the DWG) if you put it down on bare clear coat. Sealants (and DWG is a weak sealant) typically don't bond well to waxes or traditional glazes, like Red Moose. You mentioned that you did Vanilla Moose->RMG->Opti-Seal. The Opti-Seal isn't going to give you very good durability that way, as sealants won't bond well to traditional glazes like RMG. Try using the DWG instead of RMG. DWG is *meant* to be used prior to a sealant, so it won't hurt the durability/bonding of any sealant you put on after the DWG. RMG is great stuff, but if you're going to use it, you should top it with a carnauba based LSP. RMG plus a good carnauba will give you good defect hiding abilities if you need to cover stuff up. |
Thanks SuperBee, I really appreciate it. The correct pairing of different styles of glazes with either sealants or carnauba is the kind of information that is super valuable for me to know, but that can be somewhat confusing to figure out just by reading posts here. I was fairly happy with my old Vanilla Moose> Red Moose>Opti-Seal, but I like DWG a LOT and see the potential for a wetter look, which is what I am after.
Thanks to your additional info I have the confidence to try using use UPGP or OS after DWG, and know the pairing will be a good combo. I appreciate the help and look forward to triyng it out this weekend.  | |
05-22-08, 09:00
#70 (permalink)
Join Date: Apr 2007 Location: Salt Lake City, Utah Posts: 2,770 | Re: The Hype Surrounding DWG Sounds like a fun weekend, Bob, have a good time!  | |
05-22-08, 09:24
#71 (permalink)
blk45 is offline
Join Date: Aug 2007 Posts: 113 | Re: The Hype Surrounding DWG Quote:
Originally Posted by Bob D. Thanks SuperBee, I really appreciate it. The correct pairing of different styles of glazes with either sealants or carnauba is the kind of information that is super valuable for me to know, but that can be somewhat confusing to figure out just by reading posts here. I was fairly happy with my old Vanilla Moose> Red Moose>Opti-Seal, but I like DWG a LOT and see the potential for a wetter look, which is what I am after.
Thanks to your additional info I have the confidence to try using use UPGP or OS after DWG, and know the pairing will be a good combo. I appreciate the help and look forward to triyng it out this weekend.  | You can use wax or sealant over DWG. It's RMG that you have to be selective about what you top it with. | |
05-22-08, 09:37
#72 (permalink)
| | My Typical Sunday
detaildoc is offline
Join Date: Sep 2007 Location: Riverside, CA Posts: 1,050 | Re: The Hype Surrounding DWG Quote:
Originally Posted by Bigpikle well I finally managed a good clean and a layer of DWG followed by another layer of UPGP
Applied at speed 3 on the UDM with a red SFX finishing pad - went on really easy and buffed off even easier - LOVE this stuff and just exiled more bottles to the forthcoming sale  | UPGP and DWG on any shade of silver is a killer combo.
__________________ Club Flex Member
Completely addicted to the scent of Swissvax Concorso
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is On | | | | All times are GMT -7. The time now is 09:15. | | | |
