03-17-05, 05:13
pewter00 is offline
Join Date: Mar 2005 Location: Moore, Oklahoma Posts: 39 | blackheads on my nose anyone else get real bad blackheads on their nose? if so how do you get rid of them? | |
03-17-05, 06:13
| | Practical Perfectionist
Join Date: Sep 2002 Location: NE Ohio Posts: 21,178 | They make little "pore cleaning machines", gizmos that sorta vacume them out. I know some people who swear by them. Or you could get the Biore (sp?) pore cleaning strips. They're like tape that pulls the [stuff] out. Or you could use a facial cleanser made for such (aggressive) cleaning (but those always caused trouble for me). Or you could ask a dermatologist (which you should see from time to time anyhow) what to do about it. | |
03-18-05, 06:34
| | Survey Monkey
IndigoGTI is offline
Join Date: Nov 2002 Location: Dallas, Tx Posts: 433 | I'll throw in a vote for a patient girlfriend/wife with a pair of tweezers, or the Biore strips. My wife seems to have a strange fascination with removing blackheads from my nose. I also use the Biore strips occasionally, and am constantly amazed at some of the junk they remove.
-Chris 2001 Absolutely Red Toyota MR2 Spyder, 2003 Platinum Grey Jetta 1.8t | |
03-18-05, 12:52
pewter00 is offline
Join Date: Mar 2005 Location: Moore, Oklahoma Posts: 39 | thanks guys.. i use the biore strips too but they all come back so fast.. i hate it | |
03-18-05, 01:52
| | Survey Monkey
Join Date: Nov 2002 Location: Dallas, Tx Posts: 433 | You might want to consider using a light facial scrub two or three times a week. I know Clinique makes a 7 day facial scrub that I like (my wife bought it for me). It costs about $20 for a tube, but with the amount I use, the tube will last me 2-3 months. It is very mild as far as facial scrubs go, and seems to moisturize my face a little too; I notice myself not using as much aftershave lotion on the mornings I use the scrub.
04-21-05, 04:48
sspeer is offline
Join Date: Nov 2004 Location: IL Posts: 588 | Have the same problem. I'm having decent luck with using that Medicated Swiss facial scrub that's less than 3 bucks a tube at Sprawl Mart..have to do it everyday..then I try to put some astringent or toner when I get out of the shower
I'm curious about the vac. Biore works, but doesn't seem to pull most of them out..
The ProActiv stuff works well too | |
04-21-05, 05:00
scottabir is offline
Join Date: Aug 2003 Location: Grand Rapids,michigan Posts: 1,483 | hmmm sounds like a good qd and clay bar will work
2003 Mazda 6S black
Do what you love and the money will follow
04-21-05, 12:36
sspeer is offline
paint and skin...I'm sure lots of similarities can be found...
Maybe Klasse should come out with a skin care line...don't know about having the acrylic shine tho.. | |
04-21-05, 12:52
D3mon is offline
Join Date: Oct 2004 Location: UK Posts: 247 | I explained the process of paint care to my wife using skin-care analogy... got stuck at sealant though...
ex-Autoglym-er finding better products all the time!
04-21-05, 03:25
| | Who? Me?
the other pc is offline
Join Date: Oct 2004 Location: SoCal Posts: 2,156 | Quote: Originally posted by scottabir hmmm sounds like a good qd and clay bar will work | I was thinking a carpet brush on the PC set to about 3.  | |
07-12-05, 11:45
| | Super Obsessed Detailer
Dinzdale40 is offline
Join Date: Jul 2003 Location: Chattanooga, TN Posts: 568 | Biore strips don't do much to mine.....i just squeeze the skin a bit like i would a popping a pimple....tons of junk comes out...you should try it with a bit of tissue....squeeze from top and bottom on the bottom of your nose where it meets your cheek....that's where the most comes out.....i do this and exfoliate....then moisture every couple days.... | |
07-12-05, 11:51
| | []D[][]\/[][]D
truzoom is offline
Join Date: Mar 2005 Posts: 1,642 | If you've got the balls..you can get a cheap ballpoint pen, take out the ink tube, and use the open non-ink end and push it aorund the blackhead and it should force it out.
I've always used biore strips and apricot face scrub. My problem is mostly whiteheads though..harder to remove. | |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | All times are GMT -7. The time now is 08:31. | | | |
