Originally Posted by tssdetailing
very interesting replies...going to consider a smaller scale vehicle now. Thanks.
Consider what exactly it is that you need to bring. Generally I carry two 5-Gallon buckets, one with my DA inside and spray bottles hooked along the edge, another with a stack of pads and more spray bottles hooked along the edge. A shop vac. My rotary, my
Meguiar's bag which is filled with most of my go-to products (pro clay, M16,
M80,
M105, M205, Odor Eliminator) some hand applicators and some brushes. Bigger brushes get thrown in, a full package of folded MF's and a handful of odd disposable rags for metal and wiping up messes. I will throw in a few more things if I know/suspect they may be necessary. All of that can fit can easily fit into a medium-large trunk.
If you need a water reclamation system, a water tank, your own electricty source, a steamer, an extractor and an ozone generator then you may actually need a Dodge Sprinter or some type of van. What kind of mobile business, exactly, do you run? One like mine or one like the one I later mentioned?
