Autopia.org
the 'little tricks you've learned' thread
Published by Dr. Jones
05-10-02
I've been wanting to post this thread for a long time... i know everyone has little tricks and things that they use when they are detailing... tricks that seem obvious, but might not be to everyone. for instance...
recently on my black car it's been hard to keep water spots off when i wash... so i put my wash mitt in one hand and the hose in the other... right after i rub over an area with the mitt i hose it off.. this way if water spots form they are just water.. and not soap.
Even better sometimes the hose gets out of controll doing this and rubs up against the paint :scared ... i found out if i hold the hose at the neck.. right where the water comes out.. i have better controll vs holding it 8 inches or so back like i used to
Parking you car on a slope is a great way to get the water to drip out of crevices (for all us w/o leaf blowers)
If you use an absorbent towel to dry, like the Big Blue, you can put the edge in those crevices to suck the water out... But do this last... it will put really damp spots on your towell and make it harder to get the rest of the body perfectly dry
Ok i know everyone has lots... and while i'm sure someone won't learn everything from this thread... hopefully everyone will learn something.
Dr. Jones
'00 FBP Civic SI
Article Tools
By PakShak on 05-10-02, 10:44
Hi Dr. Jones,
After a wash to get water out of the crevices, I get on the freeway hit about 65-70mph and cruise at that speed for about 2-3 minutes and all the water from the crevices is no more.
Aloha,
Ranney
By E36 M Sedan on 05-10-02, 11:02
my little tip
Here's my contribution...
Have you ever polished aluminum wheels and just could not get all the residue from the polish off. My suggestion, take a clean towel with a bit of cornstarch on it and wipe the wheel. All the residue will come right off and leave the wheel shiny.
Yeah, I have issues, at least that's what my frinds and co-workers tell me.
By Intermezzo on 05-10-02, 12:22
The two tricks I can think of right now (which I'm sure most Autopians already know) are as follows:
1. Dress your plastic trim with protectant right before waxing when using a wax that stains trim (i.e. Blitz, Meguiar's #26) and the hazed wax will wipe right off when buffing.
2. Washing your car contributes greatly to the degradation of your wax protectant (more so than every-day driving, IMO). To help counter this, mix a little bit of liquid wax into your shampoo (at a ratio of about 3 parts shampoo, 1 part liquid wax), shake vigorously in a small bottle similar to a ZFX bottle and pour into your bucket. This should only be done when your car isn't too dirty and doesn't have any embedded dust because the amount of suds you'll get will be severely reduced. Make sure you rinse your car very thoroughly afterwards.
By YoSteve on 05-10-02, 01:11
when I'm using a wash mitt and not a foam dispenser, instead of using a second bucket I use the hose. I spray the mitt with full force in one direction so that all the fibers all lay one way and then rotate the mitt and spray in another way laying the fibers in a completely opposite direction, insuring there isn't anything "hiding" in the fibers. I'll remove the big MF with a mf and if I QD I'll use a second fresh towel to prevent streaks.
By Dr. Jones on 05-10-02, 01:54
after i'm done with the last step on the car i'm doing i pull it outside for the final buff... the sunlight really shows areas that were missed.
By medic on 05-10-02, 04:17
clean engine
lightly mist you cool/warm engine (not too much or with too much force or you can bust/losen a hose or have to wait for parts to dry.
a little simple green in the engine bay and let it sit
rinse off and wipe down
turn on car and drive around to get rid of the remaining water
repeat this 10 minutes process every day for a week and your engine will be much cleaner. Not so to the point of a full detail, but it'll make your mechanic happy
By Intel486 on 05-10-02, 07:11
Re: clean engine
Just a question... why would you do this every day for a week? All the engines I have done I have been able to get clean the first time.
By Jngrbrdman on 05-10-02, 07:22
Anthony's RainX application method
To apply RainX without any haze or streaks then this is the tried and true method. I apply RainX at least 3 times a week to various cars and I do it this way every time. I've even gone back to people a week later to ask them how their windshields are doing and they have nothing but good things to say. No mention of streaks or haze at all.
1. Wash window with glass cleaner.
2. Apply a bucket of RainX to your glass. I like to load it on heavy but you can use however much you like to use.
3. Allow it to dry for a little while. Vacuum the car or something.
4. Wash car. While you are washing the car, hit the windshield with your brush or mitt or whatever you are using. Wash the glass just like you were washing any other part of your car. When you rinse the car there will be no trace of haze or streaks in your glass and the RainX will be left to do its work the next time it rains.
If you were a RainX hater before reading this and haven't tried this method then bust out that RainX and give it one more chance doing it this way. Its way less work and it works soooooooooo well. If Auqapel isn't an option then this is a great way to get some beading action on your glass. =)
By JeffBruce on 05-10-02, 07:30
Probably know this but...
there are alot of post using simple greem or Hi-Intensity Cleaner or some other cleaners for wheels. I use them on "badly-rusted" wheels and they never take it all off....i follow with good old fashioned Brillo pads...and that finsihes them....I little elbow-grease never hurt....
By Guess My Name on 05-10-02, 07:49
I said it once (or twice) vinyl rubber eraser to remove wax stains on trim......
Another tip use lots of ice and beer in the ice chest and layer before going to a Mardi Gras parade....also get one with wheels so you do not have to carry it.....
By dlw on 05-11-02, 09:38
Get some fairly good micro fiber towels, wash them before first use, let them dry, take a laundry marker and mark a corner with a "G" for glass. Never, ever use them for anything but windows and never use any chemicals other than Stoner's or Sprayway or water/alcohol mix on the windows. Always wash the glass MF's by themselves. Once a wax or polish gets in the towels, it will never all wash out and they will never get your windows clean. After making sure the windows are clean the first time, you usually only have to mist a little water on them and use your "G" micro fiber towels to maintain a perfectly clean window. Also, as a beginner step, using a clay bar on your glass will get it as smooth as....well......glass!
Currently Active Users Viewing This Article: 2 (0 members and 2 guests)
Article Tools
Display Modes
You may not post new articles
You may not post comments
Article Article Starter Category Comments Last Post
The Definitive Porter Cable Accessorizing Thread 4DSC Machine Polishing 69 03-11-04 03:54
Pad Survey Thread? Scott P Car Detailing 6 10-28-02 07:31
What keeps happening to the Group Buy thread? puterbum Car Detailing 6 04-09-02 08:31
