Here's a Black Metallic 04 Bimmer 530i that must have lived in brush car washes!
I mean, this car was not only swirled to the hilt, the clear was surprisingly super hard (unusual for Black BMW's that I reconditioned previously)
So, wet sanded with 2500 grit where needed, and broke out the 3M Extra Cut and foam pads (which I changed to wool as the foam was taking too long to correct)
A 3M "Smiley"....gotta have some humor for Autopians!
After the Smiley worked in
After compounding, I used 3M Swirl Remover, then
Menzerna 106ff for some extra shine on this super hard clear coat. Power washed between process's to remove the dusting and went for the 3M Ultrafina SE.
Usually, I just add a coat of #26 with the Festool, but decided to try a product mix for grins and it worked out great. I mixed #26 and
Pinnacle XMT 360 on a finish pad and worked those products in completely. In the following pics, I did not buff a single panel and the finish is glass smooth!
I'm gonna try this same LSP combo on a waiting-in-line 2001 X5 4.4i (black of course) just to see if I get similar results.
Toto
