Some areas of the car were really bad with this and they looked pretty deep, just about every panel had random scuffs and "nicks" in the paint too that we were pretty sure weren't going to come out..
We decided to tackle them later when we got to them, in the meantime we taped the car up and clayed it with Zymol Lehm Clay III and Zymol Clay Lube, drying with a waffle weave as we went along. The car really needed alot of claying as it was pretty rough, it already showed a significant improvement in gloss once this stage was completed.
PTG readings were taken next, with the car being pretty consistant and showing an average of between 180-200microns,the bumpers were at the 80-100 mark (unusual considering they had been re-sprayed) we also suspected that there has been a smart-repair on the nearside door next to the handle....
We had planned to show you a graph of the PTG readings but numb-nuts here forgot to save the front and rear bumper batches
, sorry!
Next stage was to find a pad/polish combo, and we finally decided on a finishing pad with the more agressive finishing polish that we generally use, Ferarri paint is known to be soft and this car was no different, with 95% of the defects coming out first time @1500rpm with the rotarys.
When it came to the areas that were badly affected by micro-marring from the previous "detail", i decided to go for a polishing pad and the compound that is rather sought after just now (
) @1700/1500rpm's, this improved them slightly but they were still annoying me as you could quite obviously see them if you looked hard enough:
It was at this stage i was keen on wet sanding these areas to remove the marring but Rich pointed out that we didnt really have a huge amount of time to bring it to a level where i'd be happy, so it was explained to the owner that we could fix it at a later date if he wished but he seemed perfectly happy with the progress we were making anyway
Speaking of wet sanding - while i removed the side repeater on the nearside wing, it was apparant that there had been a smart repair on this area too, as they had just masked off the repeater when applying the clear coat which resulted in a 2 or 3mm raised edge that looked like it could start to flake very soon.
As it was a small area we had enough time to sand it back with 3000
unigrit as seen below:
Once the majority of the rotary work had been done Rich cut in the smaller areas with the PC. The rear bumper was obviously painted in single stage red as rich got paint transfer on the PC pad, this would explain the low PTG readings. While he did this i decided to freshen up the
headlights as they were swirled and cob-webbed also.
Head light before:
Head light after finishing polish & polishing pad @1500rpm's:
One of the things that let the car down was the sign of polish residue from previous details around the head lights. This was sorted with a small detailing brush and citrus de-greaser:
Before:
After:
