Old 09-15-06, 01:04   #1 (permalink)
Flying Scotsman
Dave KG's Avatar
Dave KG is offline
Porsche 911 GT3 (Black)
An early start todau, up a 6am, and get ready and met up with Bryan at 7am for the drive through to detail this lovely car - a metallic black Porsche 911 GT3.
The car on arrival looked pretty clean:
A quick discussion with the owner revealed that he uses the two-bucket method and a washmitt when washing the car, os the correct care regimes were in place. :thumb:
First off, Bryan cleaned the wheels are arches. Wheel were cleaned first with Meguiars APC and then with Chemical Guys Blue Rim Cleaner. They were then rinsed with the Karcher and dried. The arches were cleaned and then dressed with Autoglym Vinyl & Rubber Care. Once complete it was onto the bodywork.
First off, this was foamed with Autoglym Powermax3 TFR:
Then this was rinsed off, and then the car washed using the two bucket method with Autobrite Luxury Suds and dried off with a meguiars Water Magnet using Meguiars Last Touch as a lube.
Assessing the paint for bonded contaminants revealed there was very little there - clearly this car was well cared for and lived in a garage, as only mild contamination was there. So, we clayed the car using Sonus Green UltraFine Clay with Meguiars Last Touch as the clay lube.
Once clayed we could then asses the condition of the paint. The first thing that became immediately obvious was a large area of hologramming on the driver's side rear-three-quarter, clearly the result of previous machine polishing at come point. Under the Brinkmann the hologramming was clear to see, and fairly severe as hologramming goes:
and it was clear in the sunlight which was how I first spotted it:
However, across the rest of the car, the excellent care regime in place was proving to be effective, only very mild isolated swilrs on the car, which may well have been dealer inflicted when the car was new...
Given the lightness of the swirls, I first of all decided to try out a light abrasive combination on a test spot. Porsche paint, like other German paints, has a reputation for being hard but I always believe in working up through the abrasive levels on a test spot to make sure you sont end up removing more paint than is necessary. So, I trialled on Menzerna Final Finish PO106FF on a Meguiars W8006 polishing pad, applied using the Makits 9227 rotary. Spread at 600rpm, two passes at 1200rpm and then eight to ten passes (yes, that many! thoroughly break the polish down) at 1500rpm before making two final passes at 900rpm to refine the finish. The result:
"A thing of beauty is a joy for ever: Its loveliness increases; it will never pass into nothingness; .... "
Old 09-15-06, 01:05   #2 (permalink)
Flying Scotsman
Dave KG's Avatar
Dave KG is offline
Swirl free. So this was the decided on combination for the whole car, applied as above. As I worked round, after each section I carefully assessed the finish with the Brinkmann to check the clarity.
This combination also proved effective on the region of the hologramming, now with proper bright sunlight to highlight the fact the holograms have been removed:
While I worked around the car with the Makita, Bryan cut in by PC using a 4" Sonus SFX-2 white pad and PO106FF the awkward areas that the bigger rotary pad would not reach.
Bryan then applied Smartwax Rim Wax to the wheels, and Meguiars Endurance on the tyres:
Once the car was fully prepared, it was time to choose with the owner the LSP. After discussing the LSPs we could apply, we decided to go for Zymol - HD Cleanse followed by Destiny.
Bryan and I then applied the HD Cleanse, using a Meguiars foam applicator in straight lines with firm presure, leaving around half a miniute and removing with a Meguiars Ultimate Wipe. After this stage, the paint was taking on a lovely glossy and wet black look. The the Destiny - Bryan applied this by hand, and I followed round with a Zymol Wipe (microfibre) removing the residue after it had a couple of minutes to stand. Using this "two-man" method, Bryan could then keep his hands moist with the carnuaba without losing any to the microfibres.
Glass was treated with Autosmart Glass Cleaner, rubber and plastics to Meguiars #38.
Now, the afters:
Old 09-15-06, 01:07   #3 (permalink)
Flying Scotsman
Dave KG's Avatar
Dave KG is offline
Old 09-15-06, 01:15   #4 (permalink)
Bigpoppa3346's Avatar
Bigpoppa3346 is offline
Stunning work! The paint looks very liquid, with great depth and clarity. Good job.
Old 09-15-06, 01:42   #5 (permalink)
Neat Freak
audicoupej's Avatar
audicoupej is offline
Contact: Send a message via AIM to audicoupej
Yummy. That looks awesome! Great job!
I could never apply a wax with my hands, they are too dry/rough. I would mar the crap out of the car.
How do you do it without marring?
]ohn
JEMM Automotive Detailing
Old 09-15-06, 01:50   #6 (permalink)
Flying Scotsman
Dave KG's Avatar
Dave KG is offline
You may think I'm off my nut, but I moisturise my hands... I dance regulalry, and so I have to have smooth soft hands for this.
Old 09-15-06, 02:00   #7 (permalink)
sneek's Avatar
sneek is offline
oo pretty car! with wet paint!
Old 09-15-06, 03:00   #8 (permalink)
Surfer is offline
Nice, love the GT3. IMO the Turbo is borring to drive, just feels numb and not tactile whereas the GT3 feels like your connected to the road. Not to mention the turbos muffle the sound (like a loud hair dryer) and the GT3 absolutley screams, family friend has one with Manthey mods.
Old 09-15-06, 03:03   #9 (permalink)
Mikeyc's Avatar
Mikeyc is offline
Wow! Nice work Dave (and Brian too)!! You guys must be some pretty well respected detailers considering some of the exotic/expensive cars you've posted up. Menzerna polish, HD-Cleanse, and then Zymol is a combo I use on my car as well and it comes out looking dripping wet with great depth as this Porsche shows.
Old 09-15-06, 05:42   #10 (permalink)
Late Registration
mr.ikon's Avatar
mr.ikon is offline
Very very nice and wet. Great job. Some of those hood shots gives me that twilight zone feeling.
Old 09-15-06, 06:37   #11 (permalink)
SkeptiKal is offline
This car is fire.
Good job!
Old 09-15-06, 06:55   #12 (permalink)
Jason M's Avatar
Jason M is offline
I love GT3's! And great job on the detail as well. Really shines and nice depth.
LinkBacks (?)
LinkBack to this Thread: http://www.autopia.org/forum/click-brag/77698-porsche-911-gt3-black.html
Posted By For Type Date
CSX DRIVER :: View topic - Porsche 911 Gt3 This thread Refback 11-13-06 09:02
