By joining our FREE community you will be able to interact with others. Registration is fast, simple and absolutely free so please, join our community today. When you join, this box is replaced with our live chat! |
04-12-07, 01:45
#49 (permalink)
Brit6 is offline
Re: A small "how-to" on chip repair/wetsanding + spring cleaning (black G35) (56k = owie)
Picus do you do work for other people?
04-12-07, 01:59
#50 (permalink)
mose is offline
Also.....What's the going rate for chip repair like that?
04-12-07, 04:51
#51 (permalink)
Picus is offline
Yep. Click my name then my homepage.
TBH, I don't really do just chip repairs. If someone wants one done as part of a detail I will do it, because I will have time during the detail to let the paint dry. Otherwise it's not really worth the time since I have to sit around for 4-6 hours.
GTA In Detail
09-18-07, 09:17
#52 (permalink)
dmk112 is offline
Picus, I touched up some chips/scratched using your method.
Two issues:
1)When I wet sand it down it seems that it is not sanded all the way to be level with the rest of the paint but yet the primer is peaking through the touch up paint (white specs).
2) I am having issues with the paint matching, I got it from pepboys (dupi color). You said to apply clear if you have mathing issues, how does that fix it? It appears that the touchup paint is lighter than the rest.
09-18-07, 09:46
#53 (permalink)
Too Many Products
DieselMDX is offline
wow this is agreat thread
2009 Royal Blue Pearl Honda Civic LX-S
Club: Flex Member
09-19-07, 05:59
#54 (permalink)
qballjr13 is offline
Thank you so much Picus...that is a great write up and I cant wait to follow your step-by-steps and try it on my own car! Autopia kicks-a$$ because of people like you!
I know just enough to get me in trouble!
2004 Toyota 4-Runner SEV8, Natural White
1950 Chevy Streetrod, 502hp/546lb/ft torque
04-15-08, 05:01
#55 (permalink)
kenleekenlee is offline
Picus: To celebrate the second anniversary of this thread's creation (almost), I've got a question for you: How many sheets do you normally use for a touch up job? x sheets per chip/scratch? or x chips/scratches per sheet? I'm about to start the touch up process on my own car, and I would like to order a few sheets from Megs online.
If anyone else wants to chime in with their own experiences, feel free to do so.
TIA
04-15-08, 07:57
#56 (permalink)
Carvista Inc.
ScubaStevo is offline
I don't think you'll need more than one sheet of each. I can wetsand multiple scratches on multiple cars on the same piece if its cleaned properly after use.
04-15-08, 03:34
#57 (permalink)
Picus is offline
TIA
Hah, funny to see this thread come back. Like Steve said one sheet will do quite a few chips. If you're using a block you cut the paper to fit the block, and get about 4 usable pieces from that. Each piece will do 10+ chips in my experience.
One note; the sand blocks are pricey, but they last forever. I've been using one for almost 2 years now and it's not even half way gone.
GTA In Detail
04-16-08, 11:39
#58 (permalink)
Por2geezSupra is offline
is ill be using a pc with an orange pad with optimum compound, what grit sandpaper should i end with? Could i use just 2k grit and be fine, or should i use higher grits after the 2k? Would i be better off using 2k, then 3k, then buffing?
04-16-08, 01:09
#59 (permalink)
BigAl3 is offline
great thorough write-up with pics, thanks for sharing!
04-16-08, 05:53
#60 (permalink)
Picus is offline
Well it's always best to end with the highest grit you have; but you should be able to remove 2k grit marks with OC on an orange pad and a PC.
GTA In Detail
