04-11-07, 10:46
#37 (permalink)
BMW335i is offline
Re: A small "how-to" on chip repair/wetsanding + spring cleaning (black G35) (56k = owie)
Picus, I got a scrape on the underside of my front bumper (the lip). Its below the actual face of the bumper so from standing outside you can't see it. Would you approach a scrape (with quite a few spots down to the black plastic) the same way? If not, what would you reccomend? Thanks.
Jonathan
04-11-07, 06:57
#38 (permalink)
Picus is offline
Originally Posted by Reflections
Great write-up and great work, thanks for taking the time to share. Hope you're getting less snow than we are in Calgary right now.
Edit - Question:
If you're adding clear at the end and before sanding, isn't there a danger if you build up the basecoat too deep that you will sand all the clearcoat off while levelling the scratch?
Also, is it worth masking off an inch out from around the whole scratch to reduce how much area you're sanding?
Heya - when I layer the paint the layers are really, really thin, so it not a lot of sanding is required. I suppose it is possible all the clear is sanded off, but as I mentioned above that doesn't really matter anyway. The clear is more to make the touchup match than for protection.
Masking might work, I don't do it because the whole process is almost like blending paint, so making might leave funny marks. It is worth a shot though, maybe I will try it on my next one.
I know those scrapes!  The problem with bumpers is that the paint is often thicker on them, so it's harder to reach the level of the existing paint. Otherwise I would approach it in exactly the same manner.
GTA In Detail
04-11-07, 08:38
#39 (permalink)
Stuff is offline
Great write and nice paint. I'm thinking of fixing a few little chips and scratches by doing basically what you did. I'm looking at purchasing some unigrit paper. Should I just get a couple sheets if all I'm going to do doing is what you did? How many sheets per problem? Thanks for you help.
04-11-07, 10:37
#40 (permalink)
evenflow is offline
Sorry maybe I am missing it somewhere, but did you add a clear and if so where?
04-12-07, 07:17
#41 (permalink)
djomlas is offline
where can you get a sandpaper that high? all i can find at autostores is like 1200 or so...
wouold pepboys/autozone kinda places have this?
btw, you did a freaking awesome job man. i have a scratch on my car that i touched up but you can definitely see it, from putting a hardtop on by PO, so i will be using your writeup for that, now if i can jsut get the sandpaper somewhere
04-12-07, 07:38
#42 (permalink)
Stuff is offline
Meguiars Wet Sanding Supplies
You can get unigrit there and in single sheets. Thing is I'm not sure how much to buy.
04-12-07, 07:40
#43 (permalink)
Picus is offline
I didn't. I find on black it makes the paint harder to match.
I get the 3k unigrit from Meguiars Online.
GTA In Detail
04-12-07, 09:25
#44 (permalink)
djomlas is offline
thx a lot for the link man.
ill order some to fix my car
04-12-07, 09:30
#45 (permalink)
Picus- I'm late to this party, but I just wanted to compliment you on a great write-up/pics and a *super* job on your car
04-12-07, 09:34
#46 (permalink)
Picus is offline
Heh, no sweat on being late. The thread is a year old now. Just had a revival of sorts!
GTA In Detail
04-12-07, 10:23
#47 (permalink)
mose is offline
Picus.......again.....amazing write up and great work on the paint. I was wondering if, when you are in the process of waiting a couple days for the paint to cure, can the car be driven? (As in a daily driver?)
04-12-07, 01:16
#48 (permalink)
Picus is offline
Yep; not a problem. The only pisser sometimes is after 48 hours the touchup will shrink into a deep scratch, so you'll need to re-apply a bit more then wait again.
GTA In Detail
