Submit Tools LinkBack (7) Thread Tools Rate Thread Display Modes
Old 04-21-06, 02:27   #13 (permalink)
Ari Gold
G35stilez's Avatar
G35stilez is offline
Excellent write-up .
I do mine a little different, but it's wonderful to hear everyone's take.
Do you have the fullsize of this:
'02 Escalade
'08 Legacy
Old 04-21-06, 09:31   #14 (permalink)
Picus's Avatar
Picus is offline
Contact: Send a message via AIM to Picus
Thanks - and I sure do. I must admit, its interesting that non-autopians have all asked for full sized versions of the reflection pics. It seems only true-autopians appreciate the full on sun shots.
http://gtaindetail.com/fsg1.jpg = 2000x1333
http://gtaindetail.com/fsg2.jpg = 3072x2048
Cheers.
GTA In Detail
Old 04-21-06, 10:21   #15 (permalink)
Mad Scientist
djerickd's Avatar
djerickd is offline
Contact: Send a message via AIM to djerickd
Very nice! You make it look easy!
Old 04-21-06, 11:02   #16 (permalink)
Scottwax's Avatar
Excellent, excellent work. Great and informative write-up too.
That is some seriously black paint!
Scott's Mobile Auto Detailing
Old 04-22-06, 06:21   #17 (permalink)
Picus's Avatar
Picus is offline
Thanks - that means a lot coming from you guys.
GTA In Detail
Old 04-22-06, 11:33   #18 (permalink)
BlackMach1's Avatar
BlackMach1 is offline
Contact: Send a message via AIM to BlackMach1
very awesome write up! I'll be using this on my new to me GT
2000 Mustang GT
black, somewhat stock
Old 04-27-06, 02:21   #19 (permalink)
IkeRay is offline
what is a good clear coat to put on afterwards?
Old 04-27-06, 02:25   #20 (permalink)
Picus's Avatar
Picus is offline
There are a lot, clear coat is just clear paint. I use a jar of duplicolor.
GTA In Detail
Old 04-28-06, 09:43   #21 (permalink)
Picus's Avatar
Picus is offline
Over at vwvortex someone asked me to go through how I do the above but with a spray can. I apologize for any spelling errors or exclusions, I did write it quickly, been a busy week. Speaking of which, gotta go! Cheers.
Alright, so the "spray-can" how-to. This is similar to the one above except that it's 1) tougher to do, 2) requires more patience, 3) has a much higher chance of being done wrong, 4) is *much* faster when done right, and 5) looks better.
I apologize in advance for how quickly I go through this, I've been extremely busy this week. I won't be attaching many pics, but will try to explain the best I can.
- Why do we want to use spray instead of touchup?
It's faster and when done right it looks better. Often times touchup can't tackle larger jobs like bumper chips. example:
On the left is where the bumper was hit by another car. The paint chipped off and continued to peel until this spot was created. It was about 4 inches by 8 inches, touchup brush paint would have taken days to fill it in and would have looked like a big ugly mess. Here is how I spray touchup:
What you'll need:
All the stuff from above
A spray can with the appropriate color. I like duplicolor a lot, their colors are good matches, their paint dries fast and won't shrink, it's cheap, it's available everywhere, and the sprayer is half decent. You will also need a sprayer with clear in it if you have a clear coated paint job. If you're doing a bumper make sure to get the bumper version, as it has a flex agent in it.
primer
A lot of painters tape. I like the 1 inch variety for this.
A pencil and some paper (for real)
a stiff peice of cardboard or plastic that you can throw away later, it helps if it's 6x6 or larger.
an exacto knide
If the chipped area is deep (1mm or more) the paint will not fill it alone, you will need to fill it using some automotive putty. I like 3M super red putty (yes thats the name), it's highly manipulatable, dries quickly, doesn't shrink, sands down really well, and isn't expensive. It is only for small areas though (filling maybe 1/2 inch or less tops). For more you might consider bondo or another putty.
If you're using putty - a small plastic trowel thats flexible.
So time to start.
Clean the area well and then sand it edges down with some 1500 or 200 grit. You don't want it to peel any more than it has. This might open the chip up considerably, so plan for this. The one above started about 4x8 but went up to maybe 6x10 after sanding. Make sure to sand down spots inside the chip well (so if there is some paint that didn't flake off inside the maint area of the chip, try to get rid of it).
If your putty requires a base coat of any kind do it now. 3m super red doesnt, so lets fill the chip with it. This part sounds hard but it isn't. Spread the putty in the chip started from the middle, just like repairing drywall. Use the plastic trowel to manipulate it into place. Don't worry about high spots, just make sure there are no low spots - this is important. Also, dont worry about going over the edges of the chip, you'll sand it down later. The most important part is to be at or above the level of the existing paint.
Wait overnight.
Sand the area down using 1500 or 2000 grit, make sure its very smooth and get all excess that went over the edges. If you have any low spots re-fill then and wait another day to sand. You do not want low spots.
When it's sanded the fun begins!
Get your pencil and paper and put the paper over the area and trace a rough area that you'll be painting. Try to be as precise as possible as this will determine how well it blends later. mark the center of the chip with a pen on the paper.
Cover the area with painters take, all of it and make sure you go at least 4-6 inches over the area you'll be painting (so now the painters tape is over the filled area, and 4 inches on any side). Mark the center of the chip with a pen.
Hold the paper you drew on over the area and line up the dots you marked. Now use an excacto to cut out the diagram in the paper while simultaneously cutting the painters tape (lightly, dont go all the way through).
When you're done peel the tape away over the chip. How well you did this will determine how nice the area comes out.
Prime the area using a spray on primer. I use the cardboard/plastic to follow the spray can do no overspray gets on the car. Spray lightly (really, really lightly) and keep to the directions (if the can says stay 4 inches away, do it), a run is a bad thing.
If this works wait till it dries. If you get a rud wait till it dries, sand the run and re-prime.
Get your colored spray and spray. Same deal, follow instructions and spray lightly. You'll be doing at least 2 coats, maybe 3. SPRAY LIGHTLY, if you spray too much you'll have a ridge when you pullt he tape off and it'll look like ***.
wait till it dries, remember between coats you want to wait till it dries, but not all the way, you want ti spray again when its tacky.
clear the area using the same technique. if i didnt get it through to you before, SPRAY LIGHTLY!!!!!!!!! too much = too much gloss = everyone who looks at it going "hm, what happened there?" =
I do two clear coats unless it's too glossy after one.
When it's dry remove the tape and access. 9/10 times if done right you will not be able to see the touchup, however even so I like to do the following just to blend it all in.
wetsand per the above instructions (first post)
compound per above instructions
Now, in cases where the surrounding paint is in good shape this should leave you with a 100% perfect match. In cases like the bumper above the rear bumper was kind of chipped, so it was visible if you looked for it just by virtue of it having no chips. Over time it will fade to look more like the surrounding area.
Questions? Let me know. I went through this quick so I may have missed something obvious.
GTA In Detail
Old 01-02-07, 08:51   #22 (permalink)
Bioman's Avatar
Bioman is offline
Re: A small "how-to" on chip repair/wetsanding + spring cleaning (black G35) (56k = owie)
I am thinking of doing this soon on a couple chips I have on my fender. My question is, where can I buy a bottle/can of clear coat? And is there a specific brand/type I should be looking for? Thanks.
Old 01-02-07, 10:17   #23 (permalink)
Picus's Avatar
Picus is offline
Wow this thread brings back memories.
You can get clear coat paint at just about any automotive store, pep boys, autozone, canadian tire, etc. I usually buy duplicolor paints. Another place you can get it (I usee you have a G35) is an Infiniti dealership. The paint pen they give you will have two sides, one with color and one with clear paint.
GTA In Detail
Old 01-02-07, 03:19   #24 (permalink)
Bioman's Avatar
Bioman is offline
Pen? I stopped by and they gave me a small bottle of touch-up. They sell such a pen at the dealership?
LinkBacks (?)
LinkBack to this Thread: http://www.autopia.org/forum/click-brag/70028-small-how-chip-repair-wetsanding-spring-cleaning-black-g35-56k-owie.html
Posted By For Type Date
Screwed with touch up paint! - Club Lexus Forums This thread Refback 02-13-07 10:35
forum.bmw5.co.uk :: View topic - Paint, keying, spraying This thread Refback 02-05-07 10:25
Acura TL Community - Key scratch! This thread Refback 01-27-07 10:21
Toronto Accord Club :: View topic - huge scratch and scratches at the bumpers of my car This thread Refback 01-24-07 08:01
Acura TL Community - Touch up paint? This thread Refback 11-13-06 09:02
Mi-au zgariat masinaaaaa - vwForum.ro This thread Refback 11-13-06 09:02
Got a Quote today. for $947!!! - FullThrottleV6.com -- The V6 This thread Refback 11-13-06 09:02
