On with the peeling of the orange.... Decided to start near the test area and work my way around the car.
A picture of the rear fender just behind and ahead of the test spot.
After wetsanding:
Followed by
M105/Solo Burgundy Wool Pad:
Next!!!! More orange peel on the RHS door.
RHS door panel. Notice the blurred reflection on the left.
After sanding:
Halfway correcting with
M105. Can start to see the smoothness and reflection coming through.
Done:
Front RHS fender did not have orange peel but was severely swirled.
The top of the fender had swirls and some very deep scratches caused by the owners dogs.
After sanding to try and reduce the scratches:
Swirls removed but the scratches were too deep as they went through the paint.
On with the LHS of the car. The LHS front fender had some strange bubbling in the paint.
Efforts to wetsand the bubbles resulted in this:
If you look closely you can see the paint thinning out on the tops of the bubbles. Decided to stop wetsanding this panel. Was later informed by the owners son that this panel had been repainted some time ago and that he suspected the bubbles were caused by improper preparation of the panel before painting.
The worst orange peel on the entire car was on the LHS door panel.
Decided to do a 50/50 with this panel.
After wetsanding:
There was still a lot of surface unevenness evident:
Repeated the wetsanding and compounding. Much better....
