Originally Posted by DavidB
That was my bad. I moved it to the pro area and broke the images.
seech, you need to remove the HTML from your post and use the IMG tags. I did not realize HTML processing was turned on in this forum area. I will be turning it OFF.
DavidB, thanks for trying to move it to the pro area but I don't actually detail full time for a living so I thought it best to post it under C&B.
Any reason why HTML should be turned off? HTML is much better for me as I also post on my blog and I can just copy the entire post over. The
Meguiars forum also enables HTML so its easy to post on this forum and theirs. Otherwise I would have to do one post for my blog and another for the forums. Very tedious especially with this many pictures. Hope you can consider leaving HTML on.
