Old 06-25-09, 05:56   #1 (permalink)
Rupert Pupkin
jdoria's Avatar
jdoria is offline
Foam gun on an 08 G35x
This car has 3,400 miles and is garage kept. I have always questioned the value of foaming for vehicle cleanliness. (I see value in safety)
BEFORE:
FOAM GUN WITH CG CITRUS WASH & GLOSS
FOAM GUN WITH CG CITRUS WASH & GLOSS 5 MINUTES....
END RESULT:
Detailing Technology
Old 06-25-09, 06:03   #2 (permalink)
0 to 60 in one paycheck!
SuperBee364's Avatar
SuperBee364 is online now
Re: Foam gun on an 08 G35x
Surgery recovery or no, I see I need to go do some before and afters of a cannon touchless wash with Chemical Guys Citrus Wash N Gloss to save face here.
Edit: if that was just a foam gun, that's the problem. You aren't going to get good results without the power of a pressure washer.
Old 06-25-09, 06:09   #3 (permalink)
Rupert Pupkin
jdoria's Avatar
jdoria is offline
Precisely my point.
Citrus Wash and Gloss is a top product.
I think someone with a foam lance should do the same photo shoot.
Old 06-25-09, 08:17   #4 (permalink)
Originally Posted by jdoria View Post
Precisely my point.
Here's one I did just about a year or so ago...Oh brother... Here he goes again. (Lot's of pics)
Old 06-25-09, 08:30   #5 (permalink)
BigAl3 is online now
some may argue that a foam gun (or cannon), may or may not be beneficial. not everyone uses it to just use as a pre-soak, but also using it while you wash...
Old 06-26-09, 04:36   #6 (permalink)
Rupert Pupkin
jdoria's Avatar
jdoria is offline
I can see foaming just for "entertainment" on a dirty surface. In your head you are thining, "I'm lubricating the surface".
On a cleaner surface, its ONR for me.
Old 06-26-09, 07:11   #7 (permalink)
:P
ZeusCGP is offline
Just look in the bottom of your bucket after washing with and without using foam.
Old 06-26-09, 08:54   #8 (permalink)
Brodeurman69 is offline
I will say that with an actual foam cannon and pressure washer doing a rinse-pre soak-rinse will eliminate most of if not all contaminates on a properly waxed and maintained paint finish. Foam gun i can see how it wouldn't do anything without agitation.
Old 06-26-09, 01:07   #9 (permalink)
dsms's Avatar
dsms is online now
I use a foam cannon through a cam spray pressure washer with CWG all the time. I do not think CWG is strong enough to really break down and REMOVE the dirt pictured in the OP's photos. I do think however a lot of people have the wrong impression of why we pre-foam cars. The idea is simply to loosen and emulsify the dirt on the surface of the finish, that way when you begin your mechanical wash process very little scrubbing is required to achieve a clean, dirt free finish.
Old 06-26-09, 02:07   #10 (permalink)
04 Jet Black M3
Thats Fresh's Avatar
Thats Fresh is offline
Contact: Send a message via AIM to Thats Fresh
perfectly said. my thoughts exactly.
GLENN | BLACK PLEASE
Old 07-03-09, 11:08   #11 (permalink)
vroomr4 is offline
Where's the foam??? You definitely need to use a pressure washer with a foam gun. And even then you STILL have to mitt the car! The idea is you foam the car, and loose contaminants drip down with the foam. If the car was waxed before, the majority of the dirt would come off. But that looks like exposed paint with no protection, the way the dirt "stained" the car like that. But you still mitt! Now that a lot (not all) of the contaminants dripped down, there is less dirt on the on the car. Therefore less dirt on the mitt when you are wiping it down. Less dirt means less scratches to your paint and wear to the wax. Also just using CG Gloss n Wash on my sister's car, the wheels were still caked with brake dust. But a simple wet rag wiped it off with ease. Also, I foam, let it drip for 5min, then quick rinse, then foam and mitt right after foaming. Then rinse and dry.
Old 07-26-09, 03:48   #12 (permalink)
Rupert Pupkin
jdoria's Avatar
jdoria is offline
What is the suggested process with a foam lance?
I've heard:
Do not rinse off the car, just shoot foam, then rinse.
Pressure wash car first, foam, rinse.
Pressure wash car, foam, rinse, foam, boars hair (seems most logical to me)
Foam gun soap info... AL-53 Car Detailing Product Discussion 16 11-24-08 04:13
Foam Gun - First Time Use Tips/Advice? Dylan@Adams Car Detailing Product Discussion 15 09-30-07 05:14
my maintenance washes. ONR and foam gun Grouse Car Detailing 14 07-02-07 04:33
1st time with Foam Gun, Edge ShMitt, DG Aquawax and AA Tire Foam Cheetah Car Detailing 8 01-19-07 12:10
Gloss Shampoos with a Foam Gun? mjp3475 Car Detailing Product Discussion 4 01-19-06 05:35
