01-11-08, 09:26
#13 (permalink)
I used to run Washmaster
JRock10 is offline
Re: Remote start systems?
Originally Posted by DavidV
This probably goes without saying, but don't even think about doing this on a manual transmission car.
-- DavidV
 You must not know much about installing. Things have come a long way.
I own Pristine Detail Nashville.
01-12-08, 05:24
#14 (permalink)
1981 Camaro Z28
BigJimZ28 is offline
Originally Posted by hahny
i know its nice always to go automatic... but i just don't know about myself coz i still like to start my car manually the regular way to start and feel the engine roar... VROOOOM.....
My car still shakes my house when I start it with the remote
so I can always feel the engine roar
01-16-08, 03:44
#15 (permalink)
Buck_nekid is offline
[LURKER OFF]
Hello, first post here. (registered just to reply to this) I have been installing alarms, remote starts for over 15 years (independant shop,) that being said.
As stated DEI is top notch, BUT, install is everything. I have put them all in over the years, DEI is the most installer and user friendly. I won't name no names but a few of them I wouldn't put on a ex-girlfriends car if you get what I mean. The options can be near endless if you want to pay for them. Only thing you might need to keep in mind is you 'might' lose a key, depending on your car & what brand name they will use. But 99% of the companies have overcome this. A basic system (car dependent) can start at $199, thats just starting the vehicle. You can option up to full alarm, windows up & down, sunroof open & close, 2 way systems, starter, satellite based (phone your car from a plane and start it) ending up well over a grand.
Just ask the installer questions, make him your friend.
[/LURKER ON]
01-30-08, 11:02
#16 (permalink)
Detailing n00b
AAP is offline
Look at the new Responder LE stuff ... it looks killer, I plan to get one for my Acura when it is released ...
02-04-08, 06:30
#17 (permalink)
Clean Car Cosa Nostra
cajunfirehawk is offline
Just an FYI, not sure if anyone mentioned this:
My DEI (came with my car) remote start works great but I was not up to speed on how they work and assumed, wow, push the button, warm up the car, get in and go. NO, sort of, you either wait the preprogrammed period until the car shuts off or shut it off via remote, get in, then restart the carq with th key.
ALSO, and this has happened to me (LOL) if your remote system is "armed" via its out of sight on/off switch and you disconnect the battery, has soon has you reconnect the battery the car WILL START so be careful with those hands!!
02-04-08, 06:45
#18 (permalink)
1981 Camaro Z28
so.... that's how you thought it worked
 start with the remote, get in car, trun key to run, tap the brake
also there should be a pin switch on the hood to prevent the battey start problem
02-04-08, 07:37
#19 (permalink)
You know how it is when you buy a used car with no manuals for the toys...
02-04-08, 07:45
#20 (permalink)
1981 Camaro Z28
well now you know and can enjoy it
03-12-08, 02:56
#21 (permalink)
thump_rrr is offline
This is one area where you americans are paying much more than we do in Canada.
(Usually the other way around)
We get remote starters for as low as $70.00 and 2 way starters from as low as $179.00.
I installed one on my fathers car nearly 10 years ago for $70.00 and it's still going strong.
Canadian Tire
There are units specifically designed for manual transmission equipped cars.
The mode of operation is as follows.
When you park the car you engage the handbrake and leave the car running in neutral. You then press the remote start button while the car is still running.
You remove the key from the ignition and the car will continue to run.
Everyone exits the vehicle and closes the doors.
The engine is still running at this time.
You then press the start button on the remote once again and this shuts the motor off and puts the remote starter in ready mode.
This sequence ensures that the vehicle was left in neutral when the car was parked.
If anyone returns and opens a door for any reason the lights will flash and the auto start sequence is deactivated.
04-21-08, 07:04
#22 (permalink)
doni49 is offline
That's EXACTLY how my Python works--w/1 exception: I have to put the key in the ignition and turn it before I press the brake. I do NOT have to turn off the engine and then start it with the key.
Maybe there's something wrong w/your install?
Don
2007 Chevrolet TrailBlazer - White
04-21-08, 07:41
#23 (permalink)
1981 Camaro Z28
 (read post 18-20)
& F.Y.I. Python is made by DEI (check the back of your remote)
04-21-08, 07:47
#24 (permalink)
Roishe Cheng is offline
Had a Clifford system in my 99 Maxima for many years. The Intelliguard IV with remote start module. Had the installer bury the key behind the dash. I like DEI products and highly recommend them.
