Old 11-28-08, 01:09   #1 (permalink)
steelpontiac's Avatar
steelpontiac is offline
Audio Upgrade Suggestions
Hey,
I am looking to install some subs into my Ford Explorer. I already installed new door speakers and am a good woodworker and mechanic so building a mounting box for the subs and installing the system is no problem. My price range is $300 and I need some info on what equipment/brands are recommended or needed to run off a stock radio.
Thanks,
-Steel
Old 11-30-08, 05:36   #2 (permalink)
Dr. Jan Itor
ZaneO's Avatar
ZaneO is offline
Re: Audio Upgrade Suggestions
There are lots of quality brands/equipment out there. I'd recommend visiting a few quality shops and listening to different things in person. Everyone's preference is going to be different.
*I* prefer JL subs but they might run a hair higher than your budget (that's why I'm not running them right now ).
Originally Posted by David Fermani View Post
I don't care if Sal dropped a deuce in my package
Old 12-01-08, 06:04   #3 (permalink)
Ive decided to go with two Kicker 10" Comp VR subs.
They have a peak watt of 800 so when I am looking for an amp should I go with a mono and connect the two subs together or a 2 channel with each sub having its own line?
And if the amp specs say it has a peak music power of 760W but a continuous power of 125W (@4ohm) is this a good fit for the 2 subs?
It seems like I should get an amp with a continuous wattage closer to the mid-high range of the sub (5-600W), or am I wrong?
Old 12-05-08, 09:38   #4 (permalink)
Nuckin Futs
wytstang's Avatar
wytstang is offline
This amp wired @ 2 ohms will give those 10's all they need (325w RMS to each sub)
Cadence TXA-1000D - Cadence Class D Mono Power 1000 Watt Amplifier
*Note Cadence underrates there amps* also note they rate there amps @13.8 volts not 14.4 volts like many do. How many car's have charging systems that stay at 14.4 volts? I know mine stays around 13.6-13.8. Guaranteed CLEAN power.
Edit: Found the same amp on Cadence ebay page (little more but free shipping)
CADENCE 1000 WATT RMS @ 1 OHM CLASS D POWER AMPLIFIER - eBay (item 260327582625 end time Dec-15-08 10:01:10 PST)
