01-28-09, 07:08
#25 (permalink)
Yal is offline
Re: what to replace my factory head light bulb???
^ I have to agree it is selfish. Saying this doesn't bother you is like saying I'm doing 100mph in traffic but I feel safe so screw everybody else. Those HID's are horrible. The cut off is the key!
01-29-09, 08:11
#26 (permalink)
PedroDaGr8 is offline
Thanks Yal. Nice analogy.
EDIT: I want to expand a bit more on what I said before. Your comment of I know I am blinding people but I don't care is very selfish and very immature. It wouldn't take you that much more work or money to do a retrofit. It is about doing it right. Not doing it quickly or cheaply. I don't think we would be on this forum if we did things to our cars half-assed, yet that is what you are doing with your kit. Doing stuff half-assed and being a safety hazard.
Do a retrofit.
For those who are wondering what a retrofit is. You take the projector out of a car that has OEM xenon headlights and install it in your own headlights. This way the optics which are designed for HID's are in your headlight and you don't glare people.
It takes some time to do right but it is the ONLY way that works. It is all physics and DOES NOT change no matter what lies the kit companies say. So many talk about their million dollar R&D budget, yet somehow ALL of the kits come off of the same factory lines in China (yes even the ones that say Japanese parts, how does the circuit board look exactly the same as the ones in the chinese ballasts?)
Also, while many say hella or bosch or philip technology, this simply means thye use a chip on the circuit board made by that company. This says NOTHING for the quality of the design. That being said, bad ballasts are NOT nearly as bad as they were a few years ago.
Bulbs on the other hand, kit bulbs are garbage. You know how to tell. Compare the amount of salt in a kit bulb v. a real philips/osram/GE bulb. In a kit bulb the arc chamber is COMPLETELY clear or you may see one tiny spec of yellow (this may be more orangish-reddish-brown for higher temp bulbs as Indium(III) Iodide (generates the bluish color) is a reddish brown or it may have tinges of gray to it if the bulb has been used). In philips bulbs, the arc chamber is easily 1/4 to 1/2 covered with salt.
There is a reason for this, the more salt the better the quality of light, the less heat, the longer the bulb will live. The problem is the salt is expensive so the kit company scrimp on it.
If anyone has question on doing a retrofit, feel free to PM me with basic ones or checkout HID Retrofit Parts Projectors Ballasts D2S Bulbs. This is where I learned from. THeir university section has some really good threads (i.e. for installation check out JnCs rotational mounting method thread in the University).
If there is enough demand I will go through and outline some of the basic terms you will encounter in HIDs (sort of like people coming here would have no idea what a PC/7424 is without reading).
02-02-09, 01:44
#27 (permalink)
zoom zoomin at 115whp
NCZ13 is offline
that actually isnt a very good analogy at all. Going a hundred in traffic is a little (alot) bit different than being a nuisance on the road. Ive had the pleasure of being in front of my lights, and they really are bright, although i have since adjusted them to aim lower, but they still glare.
A projector retrofit would be pretty costly on my end. First getting the projectors on top of buying a new set of lights so theres no downtime during fab work. There have only been a handful of people in the protege community that have had succesful retrofits. All costing upwards of 5-600 dollars. One of the original guys to attempt it spent 800 in parts alone.
edit: also reread my post, so not really sure where your getting the whole I dont care thing from... unless your not referring to me.
2002.5 mazda Protege5
02-02-09, 01:59
#28 (permalink)
gbackus is offline
Sure it's a good analogy, you're creating a distracting, and potentially blinding situation that could cause another driver to hit something/someone because "you don't care". You are putting someone else's life at risk because you are too cheap to spend a little extra to do something right.
02-02-09, 02:13
#29 (permalink)
Godspeed Precision
D Tailor is offline
Hoen high performance halogen
I know the original poster is probably no longer interested in this information (since it was posted in JUNE OF 08) or any other in depth discussion about HID conversions (which he or she stated was something not interested in) BUT Hoen makes the best bulbs HANDS DOWN! They perfectly match OEM Xenons and put out dense white light. They last and are worth all of the cash out for them.
David The Tailor Bibiloni
Tailored Automotive Detailing
Drive with Distinction
02-02-09, 02:39
#30 (permalink)
NCZ13 is offline
Not really sure where your getting this IDC thing. How many times have you seen bright lights on the opposite side of the road and ripped the steering wheel to the left or right? None? thats what i thought.
Theres a big difference in a 90$ Apexcone kit, and a 700dollar custom projector setup.
So being to cheap to spend a little extra doesnt really apply.
02-02-09, 02:46
#31 (permalink)
1981 Camaro Z28
BigJimZ28 is offline
I realize they are blinding to people. Ive only been flashed once,.....
now do you get it?
02-02-09, 02:59
#32 (permalink)
onelazydawg is offline
Daniel Stern Lighting Consultancy and Supply
I still believe all kits and retropackages to be illegal technically is that correct?
02-02-09, 03:09
#33 (permalink)
NCZ13 is offline
Originally Posted by BigJimZ28
I didnt say i did not care, your implying I dont care. I acknowledge Im blinding people, but i enjoy the fact i can actually see whats in front of me, instead of with the candles that I had before.
and yes, to reply to the post above, HID kits are illegal and i could get a fix it ticket for it. I also have no front plate, my exhaust is certainly over 95db, as well as not carb legal.
I have been pulled over and not been hasseled, and been behind cops and not been hassled.
02-02-09, 03:23
#34 (permalink)
gbackus is offline
Wow, you're just a regular old standup citizen aren't you?
02-02-09, 03:29
#35 (permalink)
1981 Camaro Z28
for real???
they are you words I am not implying anything
new flash....if you know that you are blinding people (and bragging about it )
and not doing anything to fix it then YOU DON"T CARE
02-02-09, 03:29
#36 (permalink)
NCZ13 is offline
Im not really bother by what any of you think of my car btw. Ive done things the way I like it, and when i finally get pulled over for my mods, ill pay for them. Simple as that.
edit: im not bragging im blinding people, it was an observation.
Now if i said Holy ****, you should see how many people i blind on a daily basis, id understand where your coming from.
And i did do something about it, I adjusted my beams to aim lower. However they still glare. I accept that, but if bright light is causing people to fly off the roads, then they shouldnt be driving...
Think about it. Someone with bright lights is driving on the opposite side of the road. What do you do? Curse to yourself, squint a little, and by then the car has passed. And than you forget all about it by the time you get home.
