Old 01-21-07, 07:43   #1 (permalink)
mikebai1990's Avatar
mikebai1990 is offline
Seafoam usage?
I've heard many people sucking Seafoam through their brake booster lines to clear the carbon deposits. Is it okay to suck it in directly through the intake system? There's a part I can disconnect between the air filter and the intake, and I was wondering whether it would be okay to suck it through there, and whether the results would be the same.
Old 01-21-07, 08:14   #2 (permalink)
1981 Camaro Z28
BigJimZ28's Avatar
BigJimZ28 is offline
Re: Seafoam usage?
I would use it through as many hoses as you can get to as not to have one section clean
and others dirty
also if you use it in your gas use it for 5 min max before an oil change
and don't drive the car with it in the oil
Old 01-21-07, 08:21   #3 (permalink)
Newjack McZillion Q's
thesacrifice is offline
Re: Seafoam usage?
I thank this thread for my new signature
me: Seafoam? what's that gf: I bet it's something new and cool and you're going to want it! me: why do you say that?
gf: cause you want everything
Old 01-21-07, 08:25   #4 (permalink)
pocon1 is offline
Re: Seafoam usage?
The idea is to clean the top end and the vacuum line system. Pulling it directly into the engine probably will not do that. If you want to clean the throttle body then go through the coolant piece right above the throttle body with throttle body cleaner. Even Acura's specific top end cleaner says to run through the brake booster line. For my Subaru, I got better response by running through a line near the center of the engine. The brake booster line only feeds one side of the horizontally opposed engine. Once used properly, I produced tons of smoke and ended up with a smoother throttle response that my wife also noticed. My Acura was very little smoke and no change in the engine quality (that I could notice).
Old 01-21-07, 08:42   #5 (permalink)
67Customs
sixty7mustang22's Avatar
sixty7mustang22 is offline
Contact: Send a message via AIM to sixty7mustang22
Re: Seafoam usage?
Yeah, some cars smoke like no other for a little bit after using it. It really cleans the system up though. It is great stuff.
What if the Hokey Pokey IS what it's all about???
2005 Jeep Liberty Limited 4x4...1967 Ford Mustang Coupe...2001 Audi A4 1.8T
Old 01-22-07, 06:15   #6 (permalink)
i'm on quack
Kanchou's Avatar
Kanchou is offline
Contact: Send a message via AIM to Kanchou
Re: Seafoam usage?
that has to do with quality of gas the car's been getting.
Seafoam can be used as a weak replacement for something called Upper Intake cleaner when you suck it in a vaccum line.
Old 01-22-07, 06:34   #7 (permalink)
Surfer is offline
Re: Seafoam usage?
I've used it on our vehicles, our 05' Lexus LX470 puffed a hint of smoke as my Mountaineer did, none of our vehicles really smoked like you always hear about. With my Mountaineer though, Ford put the stupid PCV valve on the back of the V8 at an angle you basically cannot reach/access (have no idea how techs get to it). As you could run it throug hthat and feed all the cylinders etc like normal cars, but I have to use the brake booster line on that truck since you can't reach the PCV.
Old 01-22-07, 07:10   #8 (permalink)
Re: Seafoam usage?
Thanks for the advice. I guess I'll just suck it through the brake booster line. I'm not sure where it is though.... No worries, I'll go ask on the Acura forum.
Oh, and I've done the throttle body cleaning with the throttle cleaner already, so I guess if I do it with Seafoam, it's going to be redundant.
And one more question: If I suck it through the vacuum lines, is it true that the spark plugs will be fouled? I have some pretty nice spark plugs in there right now (NGK Iridium), and I don't want to waste them
Old 01-24-07, 12:17   #9 (permalink)
DirtySouth's Avatar
DirtySouth is offline
Re: Seafoam usage?
I've used Seafoam on my Saturn & Infiniti. I've put it in the gas tank on both cars. I've also sucked it through the PCV Valve on the Saturn. If your car has alot of deposits/build-up in it, you might get some strong white smoke for a few minutes, but that is normal.
Its usually best to run some through a couple days before doing an oil change, that way when you change the oil you can drain all the gunk out. As far as spark plugs, I have heard from several people that they needed to change their plugs after using it. Simply because it releases all the gunk in your engine. I would plan on changing your oil & spark plugs if you've never used it before.
Old 02-03-07, 11:03   #10 (permalink)
Interlagos Blue M3 ZCP
boostdfd3s's Avatar
boostdfd3s is offline
Contact: Send a message via AIM to boostdfd3s
Re: Seafoam usage?
I used SeaFoam on my brother's Miata which has 80k on the odo. Put it in the oil 2hrs before changing it and then into the intake manifold. Smoked like nobodys business but really cleaned the thing out. Startup is quicker and cold idle is smoother now. He claims more throttle response as well.
For my M3, i plan on doing it at 50k. I run her hard enough to keep that engine warmed up and nice and clean!
My Stable:
2006 BMW M3 Competition, 2003 Corvette 50th Anniversary Convertible, 2007 Mercedes-Benz ML500
Old 02-03-07, 11:13   #11 (permalink)
Re: Seafoam usage?
Do you guys think the smoke is so much that other people may be worried that there's a fire? Maybe I should tell my neighbors before I do the seafoam treatment.
Old 02-03-07, 11:18   #12 (permalink)
boostdfd3s's Avatar
Re: Seafoam usage?
If it smokes, it will create a smokescreen. We drove the Miata down the street and upon coming back up it was ZERO visiblity. Pretty funny though.
My Stable:
