Old 10-09-06, 05:27   #1 (permalink)
Spilchy's Avatar
Spilchy is offline
Help with cabin filter
My brother is moving out of the country and I am taking his 2005 Jetta.
The interior is filthy and smells like a wet dog . I will be disinfecting, cleaning, steaming and dressing the whole interior.
I'd like to change the cabin filter too so I have a clean one to finish out the interior reconditioning. Lord knows what's brewing in there not to mention the dust festival the interior is enjoying now.
But, where is it located?! How hard is it to swap out? What is a good one to buy? I see them all over the Internet but don't know which one to buy. They seem cheap, like $15.
Thanks for any help
Seth
club F L E X
i use sea sponges
Old 10-09-06, 05:51   #2 (permalink)
Mikhail is offline
Cabin filter usually located behind glove box...its very easy to replace it. You can find step by step instruction in the manual.
Old 10-09-06, 05:55   #3 (permalink)
twopu is offline
I was thinking about doing the same thing in my Accord, but I to can't find it. I've been told it's behind the glove box but I must be missing it. I was just going to stick with an OEM filter.
Old 10-09-06, 05:57   #4 (permalink)
I don't have much to add
SpoiledMan's Avatar
SpoiledMan is offline
Take a look at the respective car forums and you'll find your answers there. The Accord one is easy and you don't even have to be mechanically inclined. I don't know about the VW.
Black cars are fun!
Old 10-09-06, 06:19   #5 (permalink)
It's just a CAR?!?!?!
jnmttu's Avatar
jnmttu is offline
On the last generation Jetta's, it was behing a little plastic panel in the engine compartment behind the glovebox basically.
1991 Frost White Honda Accord EX
2005 Breakwater Blue Lexus RX330
2005 Satin Silver Metallic Acura TL
Old 10-09-06, 06:53   #6 (permalink)
Spilchy's Avatar
Spilchy is offline
Thanks guys! I'll snoop around and check the owner's manual and take a gander over at a VW forum.
I appreciate the help.
Seth
club F L E X
i use sea sponges
Old 10-09-06, 07:15   #7 (permalink)
sspeer's Avatar
sspeer is offline
There was an issue with the A/C ducts getting musty. The 'fix' was to run the last mile with the A/C off on high to blow out any moisture.
I think there was a TSB that told dealers to spray a disinfectant of some type in the vents
Old 10-09-06, 10:14   #8 (permalink)
Mikhail is offline
Here is the page from Haynes Manual for 2004 Accord...how to replace cabin filter.
Old 10-09-06, 10:17   #9 (permalink)
sneek's Avatar
sneek is offline
:iagree:
all you have to do is unlatch that hook thingie
Old 10-10-06, 06:42   #10 (permalink)
percynjpn's Avatar
percynjpn is offline
It depends on the make and model. The last one I replaced was my wife's JDM Mazda's, which was located under the dash, right up against the vent where the heat comes out; once I located it, it was a snap to change.
Old 10-10-06, 07:41   #11 (permalink)
Neat Freak
audicoupej's Avatar
audicoupej is offline
Contact: Send a message via AIM to audicoupej
On the MKIV VW's its under the rain tray on the passenger side. You remove the screws take the cover off, pull the filter out remove from the plastic frame and install is the reverse. It should be in the same spot for the MKV's.
They are cheap and it does make a difference. My car was smelling bad when I first turned it on and it stopped as soon as I changed it. I also plan to blast steam thru the vents to help out. Wurth also makes a HVAC system cleaner. Lysol should work fine as well.
Check out VWvortex for DIY's
]ohn
JEMM Automotive Detailing
