I have not done it on that car but it should be easy!
1.) start with a cool engine (this way there is no pressure in the system)
2.) if you have the new one, look at it there should be a spot for the hose to hook up
and some mounting holes for the screws
3.)unhook the hose, remove the screws, pop the old one out
4.)put the new one in, replace screws, replace the hose, fill and check for leaks
hope this helps
