12-21-05, 04:09
Kayak detailer
White95Max is offline
Timing belt change every 60K?
My owner's manual says to replace the timing belt every 60K miles if any of the following conditions apply, and then lists a bunch of things. Two of them (Driving the vehicle in an area where road salt or other corrosive material is applied, and driving for prolonged periods in cold temperatures) apply to me.
The previous owner said that she had the 60,000 mile service performed at the dealership before putting the car up for sale (it had 63.5K when I bought it). I would assume that the dealer changed the belt at that time, but I'm not sure.
I got a quote from my preferred mechanic for ~$400 to replace the belt. I don't have the money now, but I will have the money in February to do this if need be.
I've got 70K now...should I be worried about timing belt failure?
To anyone else with a timing belt, have you ever changed it? If so, how often?
Paul...
12-21-05, 04:33
Setec Astronomy is offline
Some of this rationale depends on whether you will have a valve crash if the belt breaks. If not, you just have the potential of getting stranded. If so, you will be looking at major engine repairs if the belt breaks. The Mazda forums should be able to tell you about this and how far past 60K the belts usually last. I knew someone who had an Altima and was getting it serviced at a foreign car place that specialized in Nissans and Hondas, and they had broken timing belts hung on nails on the wall, with the breakage mileage written alongside. There were plenty that were pretty low, 60's or 70's I think (I don't remember exactly, this was about 5 years ago).
Grumpy like Ketch...
"Well, it certainly does!"
12-21-05, 04:36
DuraGloss User
AL-53 is offline
Go to the dealership..and ask for the service records to see if the timing belt was replaced ...My girlfriend had the belt changed in her Accord at a local garage and it was around 285.00 ..the dealer wanted close to 425.00 for same thing....the garage she went to put on a kevlar type belt that is suppose to last longer than OEM belt....job took less than 3 hours....49.00 an hour labor x 2.75 hours...rest was parts....
AL
2004 Ford Ranger FXII
Bright Red
My Pitbull rides shotgun
12-21-05, 04:40
truzoom is offline
I think the problem there is that he bought the car from someone in texas?
12-21-05, 04:44
DuraGloss User
AL-53 is offline
If he knows the dealerships name then call them....ask for the previous onwers service records...could save some money if was done...
Al
Bright Red
12-21-05, 04:45
Originally Posted by Setec Astronomy
Some of this rationale depends on whether you will have a valve crash if the belt breaks. If not, you just have the potential of getting stranded. If so, you will be looking at major engine repairs if the belt breaks...
Yeah, find out if it's an "interference" type engine (as I believe they're called) and try to figure out if it was replaced before you got it. No way to exaggerate how serious this can be.
12-21-05, 04:49
Wax Sniffer
zippymbr is offline
I have done atleast a dozen timing belts mainly on Hondas. Each one that I do I am amazed at how new the belt looks at 100,000 miles. Most of us do not need to follow the severe wear schedule. 60,000 miles seems like very early to change a timing belt. One other note. Many dealerships try to get you to change the water pump, main seal and othr parts while they are there. I would pass on it, it is just another way for them to increase their business. For what it is worth if you lived near me I would be glad to help you change it. I love to work on cars.
12-21-05, 05:14
Kayak detailer
Yes the dealership is in Texas. I have all of the service records, but I don't recall seeing anything about a timing belt. I'll check again though.
Setec, it was brought up on the Mazda forums, and guy is at almost 200K, and hasn't replaced it yet. In fact, he said he hasn't replaced anything other than simple things like tires, filters, etc...
Paul...
12-21-05, 05:20
Kayak detailer
Nope...nothing about a timing belt. I don't have any record of any services performed at or near 60,000 miles.
Paul...
12-21-05, 05:24
So, is your engine an "interference" design?
12-21-05, 05:27
Kayak detailer
I don't know...I'm looking in the owner's manual now, and I'll look/post about the subject on the Mazda forums.
Paul...
12-21-05, 06:31
Considering the labor cost is the same if the water pump fails 10,000 miles after changing the timing belt, to me it is worth spending another $50-75 for a new water pump. Bearings, tensioners, seals, etc are usually fine when the first timing belt change is done but probably should be done when the belt is changed the next time.
The timing belt on my 626 was done at just over 64,000 miles. I now have 119,800 miles on my car. I guess if the first one was fine to 64k, the second one should be fine to 128k.
