Old 09-04-05, 10:08   #1 (permalink)
JohnnyDaJackal is offline
Contact: Send a message via AIM to JohnnyDaJackal
Recommended Oil Change Intervals?
Hello:
I would like to get some opinons on how often I should change my base Acura RSX's oil. According to the manual it says to change it every 10k miles/1 year whichever comes first under normal conditions, or every 5k miles/6 months for severe conditions. I feel changing it every 3k miles/3 months is a waste of money, especially when Acura recommends I can go much longer intervals. I was thinking about following the 5k mile interval, even though I don't drive under severe conditions. I really don't like the idea of leaving it for 10k miles or 1 year. I do drive mostly city(stop and go), and mostly for only 30 mins or less. I also drive *very* conservative, never speed, rarely VTEC, usually change gears at a lil under 3k rpms. I was thinking about it though and since I really don't drive my car that much, and only go to school(20 mile roundtrip) 3 days a week, it will probably be over a year before I hit 5k miles. I did read somewhere that someone recommended changing your oil at earlier intervals if you drive under 30 mins due to water getting in or something? So my question is what would you recommend as a good oil change interval? I'm now thinking every 6 months change oil and filter, but even that sounds a little too often. Let me know what you think. Thanks!
btw a little OT but what do you guys think of Purolator PureOne filters? I've searched and it seems people think its too restrictive, but when I was lurking the forums on bobistheoilguy it seems like a lot of people recommended them as a really good filter for the price. Just want to know because I received 4 brand new ones as well as 2 oem filters from a fellow member on CRSX who totalled his RSX.
John
2002 Nighthawk Black Pearl Acura RSX
http://www.flickr.com/photos/jackal829/
Old 09-04-05, 10:21   #2 (permalink)
Lowejackson's Avatar
Lowejackson is offline
If your happy with 5K intervals I doubt many would argue with you
Old 09-04-05, 11:20   #3 (permalink)
Hayabusa
atticdog's Avatar
atticdog is offline
here is a quote from a oil filter comparison
http://motorcycleinfo.calsci.com/FilterStudy.html
Pure One
PL14610 $6 50*.39*2.36 92 Silicon Silicon A A This is how an oil filter should be made. The anti-drainback valve is double the thickness of any other here, and obviously seals very well. The media is the best available, and there's a lot of it. The bypass valve is made from a laser-cut piece of stainless steel, and just can't bind or jam.
08 Scion XB Gold Rush
03 Toyota Echo 40+ MPG
01 Suzuki Hayabusa GSX1300R
Old 09-04-05, 11:31   #4 (permalink)
Not the Stig
chml17l's Avatar
chml17l is offline
You didn't metion you were going to use synthetic oil, but if you want to have the best protection and an extended drain interval synthetic beats dino oil hands down. Many manufacturers are recommending new car drain intervals upwards of one year or 10,000 miles as you have mentioned. I don't think you can go wrong with a quality synthetic like Mobil 1, Amsoil, etc. There is some debate over whether the US version of Castrol's Syntec is technically a true synthetic (IMO it isn't), but I know friends that have used it exclusively and never had any problems evethough Castrol just uses a highly refined dino oil for its base stock.
The Purolator filters seem to have good overall filtration and design from what I've read and seen reported when they have been cut open and the internals have been exposed. I really don't think you can really go too far wrong if you would stick to the OEM Acura filters either. The Mobil 1 and K&N oil filters would probably be another good choice, too.
The most important aspect of this would to be sure to drive the vehicle long enough that the engine's water temp. gets up high enough so that any internal water condensation in the oil has a chance to "burn off". Many short trips that don't allow sufficient engine operating temps. are tougher on the oil and engine.
Old 09-04-05, 12:07   #5 (permalink)
Mike-in-Orange is offline
I can only assume Acura recommends synthetic oil with those intervals. Since most of your driving is city/stop & go I would opt for the 5k intervals, even though you baby the car.
Old 09-04-05, 12:34   #6 (permalink)
Got secondaries?
Aurora40's Avatar
Aurora40 is offline
My car has an oil life monitor, and 10,000 miles suggested changes aren't uncommon with non-synthetic oil. Oils and engines just get better all the time. I'd go with the manufacturers recommendation.
Water can get in oil all the time, water is a byproduct of combustion. The problem as I understand it is if you don't get the oil hot a fair bit. Then the water won't evaporate out. So if you always make short trips, this can be more of a problem. I'd think 30 minute drives would be plenty long, though, to warm the oil up.
Sounds like once a year changes would make the most sense for you, as that is within the recommendation for you and would only be about 5,000 miles on the oil.
Old 09-04-05, 12:39   #7 (permalink)
atticdog: Thanks for the link, pretty interesting review of oil filters.
chml: I was actually planning on using dino oil. My owner's manual doesn't recommend synthetic on the base or Type S. It does say if you want to use it you can as long as it meets specificataions. As I said before I don't beat on my car and since the manual doesn't require the synthetic i'll just use the dino. I'm also not sure about the OEM filters now that I looked at mine. It appears they are manufactured by Fram. I've read a couple things here and there about different filters and different preferences, much like a wax or sealant is discussed here, but one thing mostly everyone agreed on was the lack of quality of Fram filters. The only advantage of using the OEM filter would be if something did happen to my car, and I took it to get serviced, thats one less thing the dealer can void the warranty on. When you say the engines water temp, what exactly do you mean? Are you talking about the engine temperature gauge?
John
Old 09-04-05, 01:57   #8 (permalink)
Pontman43's Avatar
Pontman43 is offline
You obviously take care of your paint, thats why your here. So why dont people take care of their engines? Sever conditions is defined as driving around town, basically everyone who drives their car is considered sever conditions. The more you change the oil the better. Oil does break down around 3-5K so change it. Best way to check if your oil needs to be changed is to check the dipstick. Your car also takes 5W20 which is actually a new oil that is a synthetic blend. It is a better oil and will last longer but 10K is out of the question. I personally change my oil every 3K and use synthetic, its probably not needed, but neither is waxing, polishing, or sealing your car once a month. What I'm trying to say is your engine needs to be taken care of properly too, even if you cant see it.
Old 09-04-05, 02:58   #9 (permalink)
Mighty HD is offline
Contact: Send a message via AIM to Mighty HD
www.bobistheoilguy.com
Pure1 filters are some of the best, rightu p there with M1 filters
Mighty Hd
Old 09-04-05, 03:00   #10 (permalink)
LSP=(winter)?#16:RBJE;
Amused's Avatar
Amused is online now
john - why don't you check out superhonda.com or clubrsx.com? there's plenty of info there related to your question. search for oil change and you'll get more than enough feedback and links to oil analysis sites for your car. if you sift through the 16 year olds crap you can actually find some sound information. i used to own an integra gs-r and prelude type-s and still frequent those sites.
my suggestion for your rsx, stick to honda/acura oil filters and use an oil of your choice, either dino or synthetic as long as it's within the recommended grade and API. change every 5k or 3 months, whichever comes first. i would suggest this to people who drive 25k or 5k a year. and since you drive conservatively, 5k should be fine for you. i'd suggest 3-4k if you were aggressive.
MY07 350Z Grand Touring Carbon Silver
Old 09-04-05, 03:08   #11 (permalink)
94BlkStang's Avatar
94BlkStang is offline
Not to pick on you, but what does checking the dipstick tell you other than the level?
Old 09-04-05, 04:13   #12 (permalink)
lbls1 is offline
My philosophy is at every 3,000 miles or at the maximum time of once per six months. On my past cars, I would change the oil after using one quart, instead of adding indefinitely. On those cars, sometimes they would make it to 3k before using a whole quart, and a couple of those cars actually went through a quart of oil before 3,000 miles. My current fleet will not use near a quart of oil before 3k, so the aim with these cars is to maintain a clean body of engine lubricant.
If you are not sure, then the best source may be found either with your dealer or a excellent mechanic that is familiar with your car. I have never needed an engine overhaul or major engine work with using my oil change intervals, however.
PS: You can tell how clean the oil is with a simple method of checking your dipstick, in addition to seeing what level it is at. New oil (but not a new lesson) will have a light brown-gold, almost transparent type of texture, and when your oil or synthetic has been used up to 3,000, it would've changed color to a considerably darker texture. You can guage whether it will need changing by seeing how dark the color has changed, while considering how long the oil body has been in the crank case. If you are not near the "add oil" indicator, and if you feel it should stay in the crank case longer than 3k, then at least follow your minimum oem spec.
'02 CAMARO SS SOM; 5.7L LS1/FLS6B
'08 TBSS AWD Black Granite Metallic
Lifba Member 2009
