08-24-05, 02:13
Kayak detailer
White95Max is offline
If you skip gears with a manual tranny...
...does it matter if you go 3rd to fifth, or should you push the gear lever into 4th for a second before putting it in 5th?
IOW, consider the two options I tried to explain above...
1. Accelerate in 3rd gear. Push clutch in, move gear lever out of 3rd, push into 4th (clutch pedal still depressed), then move gear lever to 5th gear position. Let clutch pedal out.
2. Accelerate in 3rd gear. Push clutch in, move gear lever out of 3rd, move gear lever to 5th, let clutch out.
Is one way better for the synchros or anything?
Paul...
08-24-05, 02:23
IMO it won't matter since you're not "double clutching" anyhow, and nobody double clutches their upshifts these days.
Doing 3-5 isn't really any different from the "skip shift" system built into many new cars. That system forces a 1-4 (IIRC, been a while and I seldom let the 'vette do it  ) to save fuel/emissions/whatever.
But whether you should skip the gear or not is really a matter of lugging/bogging the engine if your gears are spaced too "wide" between 3 and 5. It might not be a good idea for this reason but it's not gonna hurt the tranny/synchros any as best I can figure.
08-24-05, 02:30
Got secondaries?
Aurora40 is offline
Hey Accumulator! What 'vette do you have??
Also, does double-clutching on the upshift help? I'd think the fact that the clutch is out and the engine is spinning faster than it will be on the next gear would already help the synchros. Is that not true?
Also, I'd think going 3-4-5 if you aren't gonna use 4 would just be more wear on the 4th gear synchros for no real reason. But I don't know that much about trannies...
08-24-05, 02:54
I don't have much to add
SpoiledMan is offline
I do 1-3-5 shifts on the freeway in traffic regularly(whenever I drive my manual car in traffic) and have had no ill results. I've done this with a number of cars now that I think about it. Just remember to slow your shift a little so that the RPM's match a little better.
Black cars are fun!
08-24-05, 03:01
Ari Gold
G35stilez is offline
I've never understood the point of this?
You loose accleration and power, you put more stress on the block at those low RPM, etc.
Someone care to explain?
'02 Escalade
'08 Legacy
08-24-05, 03:07
Well, lazy mainly. I wouldn't think it would stress the block or anything else as opposed to revving to higher RPM's. Probably saves some gas too. My Integra is no race car by any means when driven like this but it moves along nicely if shifted at 3500 or so.
Black cars are fun!
08-24-05, 03:08
Quickstrike is offline
My father always shifts from 2nd gear to 4th.. he thinks it is more fuel efficient.
But to go to 2nd to 4th and get ideal revs, he shifts @ 4000+ rpm compared to his usual ~2500 shift to 3rd. In the end I think it is about equal.
08-24-05, 03:08
Spilchy is offline
Yeah! Ditto on that!
Seth
club F L E X
i use sea sponges
08-24-05, 03:29
Kayak detailer
Sean, I do it because often I accelerate to the speed limit in 1st, 2nd, and 3rd. If I'm already at the speed limit (40mph, 45, 55), what's the need for 4th? I might as well just go into 5th since I'm going to end up there anyway. If I'm going on a freeway ramp, then I use all 5 gears.
Same thing with a 30mph zone. I often accelerate to 30mph in 2nd, and then just go into 4th. My car needs the higher revs to move at anything other than a snail's pace, so I stay in 2nd until I'm at 30. Then shift into 4th because I won't be accelerating much or any at this point.
Paul...
08-24-05, 03:37
Ari Gold
If I am correct, I read Accumulator had a Mallett Vette  .
On topic: Guess I wonder since my car has no torque and power is in the upper RPM. I like shifting and prefer to down/up shift every gear
'02 Escalade
'08 Legacy
08-24-05, 03:43
Terran is offline
I do it sometimes when I want to accelerate really fast for the fun of it, but don't want to go so fast. I'll be in 2nd or 3rd at 50-60 and not planning to go any faster, so I'll just shift to 5th. I don't think it will do any harm. Make sure you don't bog the engine down though
08-24-05, 03:51
Registered Utilizer
Zab is offline
I do this too. Most situations are when I find myself poking along in traffic in 3rd gear @ 30-40 mph from slowing down and then needing to resume speed (red light ahead that turns green, someone turning left who find the gap in traffic, etc.). Basicaly, fast enough that the car does not lug in 5th and no need for brisk acceleration.
John
1987 BMW 325is (new to me), 1998 Ford Expedition (Buffy), 2000 BMW M Roadster (Lucille)
