02-18-05, 10:17
Setec Astronomy is offline
Mobil 1 In 5 qt. Jugs
Has anyone ever seen these anywhere but at WalMart?
Grumpy like Ketch...
"Well, it certainly does!"
02-18-05, 10:22
MS22 is offline
Advance or PepBoys used to have them I can not recall which one, however I have been going to Walmart for them for a while now. How can you beat 5 quarts of Mobil1 for $19?
02-18-05, 10:29
I don't have much to add
SpoiledMan is offline
Sure you can, Costco = 6 quarts for 23.33.
Black cars are fun!
02-18-05, 10:32
rjstaaf is online now
You might want to drop by the forums at www.bobistheoilguy.com. Mobil1 just revamped their entire line and added the new Extended Performance line. There is quite the controversy brewing in the forums about Mobil1 regarding the possibility that standard Mobil1 has been downgraded and the new Extended Performance Mobil1 is basically a slightly upgraded version of the old Mobil1.
http://theoildrop.server101.com/ubb/...c;f=1;t=009707
It will be very interesting to see how this works out after a few more people start getting used engine oil analysis on the new oils.
02-18-05, 10:42
Originally posted by rjstaaf
There is quite the controversy going on about Mobil1 regarding the possibility that standard Mobil1 has been downgraded and the new Extended Performance Mobil1 is basically a slightly upgraded version of the old Mobil1.
Hmmm....I'll look into that. On the one hand...that might be one response to the unfavorable (to Mobil 1) gov't ruling about what constitutes "synthetic" oil; on the other hand, Mobil still states that the regular Mobil 1 meets the Corvette synthetic spec...although looking that up I see the Syntec does too...
And, darn it...they had the Extended Performance at WalMart and I forgot to look what the price was.
02-18-05, 10:44
Ari Gold
G35stilez is offline
Bob: Is this just regular Mobil 1 or is their Super Synthetic line as well?
'02 Escalade
'08 Legacy
02-18-05, 10:46
Sean,
Mobil 1 is the Super Synthetic Line and yes this is what I am talking about.
This is something we will likely see more of. The API has adopted the new GF-4 standard which in a nutshell is going to force some oil manufacturers to reduce additives if they want to display the API mark. This is basically along the same lines as the VOC regulations which are affecting the products we all use.
http://api-ec.api.org/about/index.cf...2003002000000#
02-18-05, 10:47
Ari Gold
Yikes!
Well I have to ask you then...What are you going to do? Are you using Mobil 1? What do you plan on switching to?
'02 Escalade
'08 Legacy
02-18-05, 10:51
I don't think anyone is saying the Mobil1 is bad or to stay away from it but, if the initial somewhat limited results that are out are any indicator, the additives have definitely been reduced in the standard Mobil1. I will probably be moving to the Extended Performance Mobil1 or possibly even Mobil 1R which is their racing oil. There are several guys over at the forums at www.bobistheoilguy.com running Mobil 1R and it is showing very favorable wear results from used oil analysis. I was considering switching even before I heard this so this news was not a factor for me.
Mobil 1R Racing Oil
02-18-05, 10:58
MS22 is offline
I really doubt that Mobil would downgrade the quality of their supersyn and go all out with the extended life line. There are too many manufacturers that use Mobil1 synthetic as their OEM oil, I can not see them possibly jepordizing all of those lucrative contracts in order to promote a new line of oil, that would be really stupid business.
However, if by some one in a million shot these rumors are true there always is Syntec, Royal Purple, and Redline.
02-18-05, 11:05
Here is a snippet of a post from the thread I linked to above that includes some VOA (virgin oil analysis) data. Again, the oils have just been released and there isn't a lot of data so take this with a grain of salt.
The first analysis is of standard Mobil1 from last year, the Second from standard Mobil1 from this month and the third is the new Extended Performance Mobil1.
Again, this is virgin oil. If you compare the first two sets, the additives do appear down in the second set which is the newer standard Mobil1 whereas the first and third set compare prettly closely which is the older standard Mobil1 and the new Extended Performance Mobil1.
On October 1st 2004, Olympic posted a VOA of M1 5W-30 SS with the following results:
Zinc: 1000
Magnesium: 20
Calcium: 3000
Phosphorous: 902
Molybdenum: 87
Boron: 182
On February 10th, Stinky posted a VOA of the current M1 5W-30 with the following results:
Zinc: 775
Magnesium: 13
Calcium: 2380
Phosphorous: 678
Molybdenum: 92
Boron: 76
Stinky also compared the M1 with the new EP VOA and the current M1 EP 5W-30 VOA showcases:
Zinc: 1058
Magnesium: 15
Calcium: 2822
Phosphorous: 948
Molybdenum: 83
Boron: 251
Ok different labs were used for these different VOA's and of course the Supersyn additive isnt included in the VOA numbers.
However, the new EP addpack looks similar to the old M1 add pack with the new formula of regular M1 taking a big overall hit on additives. The only major boost that I can see in EP versus older M1 is in Boron. Magnesium, Calcium, and Moly are all down and Zinc and Phosphorous get a slight boost.
New M1 versus old M1 showcases major drops in all additives except for a slight boost of Moly.
If these VOA's are accurate and I feel that they are then a lot of the newly enhanced additives in EP over regular M1 comes from reducing the adds in the normal traditional M1 oils. Maybe GF-4 is to blame for this but new M1 does not look to me to have the same solid add pack as the old M1. Its been reduced and downgraded.
Now when Mobil upgraded from Tri-Syn to SuperSyn the increase in adds was obvious and noticable. However next generation of GF-4 SuperSyn seems to have reduced adds.
So yes, I believe that they have downgraded their lineup of regular M1 oils. And I dont think Olympic or Stinky skewed the Voas just to confuse me.
02-18-05, 11:09
I have been reading a little on this now, and the reduction in additives seems to be due to newer specs which are intended to reduce emission system problems, and not due to "watering" the oil down...at least that's the "company" line.
Now, to try to get this thread back on topic, anybody know of other places that sell the 5-qt. jugs?
