That stinks, sorry to hear that happened. As far as the paint goes, someone hit my car and had to have parts replaced and repainted. I took it to the dealer thinking that they would for sure be able to match the paint. (03 350Z) I got the car back, and it was totally covered in dust (probably on purpose) so it was hard to tell in the light of the body shop whether it matched or not. The next day I cleaned her up and she was two-toned. In the sunlight it was painfully obvious. Paint didn't match at all, and not to mention the swirl marks all over a previously un swirled car. We took her back, had the owner of the dealership look at the crappy job they did, and they ended up doing the paint job over, and subbing out the work to a pro detailer to remove the swirls. Moral here is to make sure they guarantee the work, and check out the paint job carefully in several different lighting situations before you accept the job has been done correctly. Also, unless they are pro detailers too and not just a body shop, tell them NOT to wash your truck--more than likely they will not treat it like you would. Good Luck I hope it turns out for the best.
"Loose Lucy"
2003 Nissan 350Z
Brickyard Touring 5 A/T
