Old 11-05-03, 02:19   #1 (permalink)
medic is offline
cleaning battery terminals
Had to get the car battery replaced yesterday and the tech used something I'd never seen before.
It's a sodium bicarbonate (can't spell) spray. Bascily a spray form of baking soda. They tech sprayed my battery tray and within a minute it was totally crud free.
I always had to pull my battery cable off and remove my retaining strap to soak them in a baking soda solution to clean them. This spray should make things a lot easier since I can just pop the hood, spray, and wipe off a few minutes later - no need to remove anything and no need to reprogram the stereo presets. I picked up a small can for $2 at autozone.
They also have a $2 can of anti-corosion sealent to use on the terminals. I'm using this instead of the petroleum jelly trick.
Old 11-05-03, 02:30   #2 (permalink)
rightlane is offline
All I know is that baking soda neturalizes the battery acid. After cleaning I use baking soda to stop the acid.
Old 11-05-03, 02:41   #3 (permalink)
Dale DeSteno's Avatar
Dale DeSteno is offline
INNNNNNNNNNNTERESTING! I am about due to clean my terminals anyway. Might have to check that out. There is also a terminal cleaner on the Autopia store....Wurth, I believe.
Up till now, I have used warm Coke mixed with Baking Soda, pour it on and the crap disappears. Pretty ghetto, tho!
Carnauba Junkie!
Old 11-05-03, 03:50   #4 (permalink)
Spilchy's Avatar
Spilchy is offline
baking soda and distilled white vinegar works too.
kind of like your volcano science project when you were a kid!
Seth
club F L E X
i use sea sponges
Old 11-05-03, 05:34   #5 (permalink)
medic is offline
yeah, this spray is basicly baking soda also, but it will coat the terminals until you wipe it off so it stays on their longer which seems more effective, and it's easier and cleaner to apply IMO then the baking soda solution I used to pour on the terminals. It always seemed to run onto other stuff and I was afraid it carried the battery acid with it. I guess I could have used less water and made a paste, but now it just seems like too much trouble when a spray is availible.
I'll have to take a look at the autopia terminal cleaner...
Old 11-06-03, 12:05   #6 (permalink)
Cya, & take the care eh?
4DSC's Avatar
4DSC is offline
Sorry for a minor thread hijacking here but I was wondering if anyone knew if those funny red and green felt anti-corrosion washers for the battery terminals actually do anything or not?
Thanks.
Brian
Old 11-06-03, 09:04   #7 (permalink)
MBZ 500E is offline
The baking soda spray sounds like a good idea, is it just baking soda/water or does it have other components?
4DSC,
I currently have a set of the Anti-Corrosion washers on my car and they seem to be working well. I've used them on other cars as well with good results. They apparently have an acid neutralizer that prevents corrosion on the terminals. For 99 cents you can't go wrong. Only difficulty you might see is that they're a bit thick and it may be difficult to slide the clamp over the terminal if you have a ton of accessories.
Here's a shot of what they look like on mine.
Afshin
90 Porsche 928 GT - Marine Blue
09 MazdaSpeed3 - Metropolitan Gray Mica
04 Honda Pilot - Silver
Old 11-06-03, 05:08   #8 (permalink)
medic is offline
there's some other stuff in there...I'll look at the ingredient label
as far as teh felt things go, they do work pretty well, but I have still gotten corrosion that starts at another point and ends up growing everywhere otehr then right by the posts.
Old 11-06-03, 11:33   #9 (permalink)
4DSC's Avatar
4DSC is offline
Thanks guys, I guess I'll get a set then. I'll probably have to replace my battery next year sometime.
Brian
Old 11-07-03, 12:41   #10 (permalink)
medic is offline
the spray has baking soda, water and some ethanol and butane; the last two are probably as propellants for the spray
Old 11-07-03, 12:50   #11 (permalink)
Scottwax's Avatar
If you can get them in Canada, the Autozone Gold Batteries are terrific. Normally, I am lucky to get 3 years out of a battery. I got more than 4 1/2 years with the Autozone Gold and I have underdrive pulleys on my car. Plus, for my car, it has 1000 cold cranking amps and 110 minute reserve!
Scott's Mobile Auto Detailing
Old 11-09-03, 03:24   #12 (permalink)
bet993 is offline
Afshin
Have you ever gotten corrosion on your MB battery? I ask because of the 4 cars I have owned that had the battery in completely environmentally protected areas (trunks - like the MB) I have never gotten any corrosion.
Brian
2007 Black Cayman S
2000 Black BMW 328i
