07-03-03, 01:00
Searching for the facts
BradE is offline
Check your tire pressure!!
Well, my story is interesting and sad at the same time. I had some new tires installed on the Explorer a week ago. Due to my own lazyness I didn't bother to check the pressure. After a week of driving, the X just was not driving right. This morning I decided to get off my lazy butt and check the tire pressure. The two rear tires had 37 psi, front driver tire had 41 psi, and the front passenger has a whopping 46 psi.
Ford spec on Explorer tires is 30 psi all around. As you can see, the idiots at the tire shop didn't bother to put the correct pressure in.  Incorrect tire pressure is dangerous (could cause blowout  ), and can hurt ride quality and gas mileage. Moral of the story is, don't be lazy like me. Check your tire pressure often! Especially after any type of work is done on your vehicle.
07-03-03, 01:30
Lazy Perfectionist
Iconoclast is offline
Yeah some shops just seem to "eyeball" it when filling the new tires. Same thing happened to me, only I caught it right away. Good tip.
99 Jetta
02 WRX
Growl Boxer Growl
07-03-03, 01:37
Cornholio Rules!!!!
Smoker is offline
They dont call em 'Exploders' for nothing yaknow.
07-03-03, 02:24
Mmmmmm, forbidden polish
gnahc79 is offline
just checked and inflated mine today  . Nothing horrible, all four read ~28-30 psi when it should be 35 psi.
btw, already common knowledge but:
1) take the measurement when the tires are cold (i.e. first thing in the morning)
2) don't trust the gas station readings, double check with your own gauge after inflating.
07-03-03, 05:22
Spilchy is offline
I take weekly readings in the morning with my digital gauge. I have a little air tank and fill em' right in the driveway. My tires ALWAYS have the proper pressure.
Seth
club F L E X
i use sea sponges
07-03-03, 05:33
Mr. Anderson?
2wheelsx2 is offline
Weekly readings are good practice, especially on garage queens. On daily drivers, my rule of thumb is at least once a month. And check things like oil and coolant, etc. at the same time.
The general rule of thumb is a 10% rise in pressure from cold tires to operation temperature. Proper inflation prevents uneven tire wear, improves grip and fuel economy too. Plus it'll prevent dings on the rim (from too low a pressure) or rough rides (excessive pressure).
Gary
07-04-03, 03:17
Cya, & take the care eh?
4DSC is offline
Ugh.  I bet the guys who installed those tires on your Explorer just pumped as much PSI into them as needed to seat the beads (pop!), then just mounted them!
Brian
07-04-03, 04:27
BradE is offline
Would not suprise me at all Brian. I've noticed most of the "shops" in my area are either staffed by idiots, or the try and rip you off. Back when I had my Jag I had an A/C leak. One of the local shops found the compresser kick out switch on the back of the compresser leaking. They tried to tell me they had to remove the compresser to get the switch, yada yada. The entire bill was going to be $900. I said forget it. Went home, did a little reading through the shop manual, none of that stuff needed to be removed. I went to Jag dealer and purchased the part, it took all over about 5 minutes to install.
So, shop wanted $900 to "fix" it.
Cost me $74 and took about 5 minutes.
Why can't there be more honesty in the Auto repair industry?
Too bad I didn't have a machine to put the tires on the rims, or I would have just done it myself.
07-04-03, 05:01
Mr. Anderson?
Most motorcyclists complain about the same thing. The shops charge a huge premium for the tires, and then still ding you $35 a tire to mount them. And you still end up with scratched rims....
Gary
07-04-03, 07:57
Never Ending Soda
94NDTA is offline
I just got new rims and tires, the first tried charging my $150 because they used this fancy machine that doesn't scratch the rims, but the neglected to tell me this price before they used it, because I called earlier and they said it was $48, so I got it for $48. ANYWAYS They over inflated my Nitto 555R Drag radials, to 56psi!! They normally run 25 psi or lower!
Making swirl marks my b*tch, one car at a time.
07-04-03, 08:08
BradE is offline
So the idiot syndrome at tire shops just isn't limited to Cincy eh?
New rule for tire shops, you must be able to fill a tire to the proper PSI!!
07-04-03, 08:35
phareous is offline
Checked mine today...a nail had gotten in and broken off. But it was leaking so slow it was almost unnoticable...but when checking the pressure it was only 3/4 what it should have been. Had to dunk the tire in water to find the leak.
