Originally posted by Scottwax
I've done them, but now you have to recycle the old anti-freeze, so really, it is easy to take it to your local lube goons and have them do it. The one by me hooks it up to a machine and flushes out all the old coolant and replaces it with new. Even the best home flush and fill kits will probably only get about 90% of the old coolant out, and you still have to take the old coolant somewhere to be recycled. Best of all, it was only $69.99 and took about 20 minutes.
I agree, only thing is you need to watch these guys like a hawk and have some shop rags on hand... I would've had coolant all over my engine compartment if I hadn't chewed the guy out for being so d@mn sloppy...
and as for Water Wetter, I assume you're referring to the Red Line product? I have been running this for about a year in both my and my wife's vehicles, and it really does seem to help with the efficiency of the coolant, and I noticed about a 10% drop in coolant temp. on the dash gauge (210 before to about 180-90 after) So at $8 a bottle from autozone, and needing only one bottle per vehicle per system flush, I'd say go for it.
Another thing you may want to do is before you take it to have the coolant done, try to flush and rinse out the overflow resevoir as much as possible... if yours is like mine was, its probably got alot of sediment and crap in there. You'll want to remove this to make sure the new stuff is as clean as possible.
