squeeling - what can it be?
For the past few weeks, I've had this intermittent squeeling coming from the right side of my car. Sounds like it's coming from the front passenger side, but it could be the rear and just messing with me.
Anyway, the noise is a high pitched squeel like something needs to be greased. The noise will just suddnely appear, but after I come to a stop and start moving again the sound is usually gone. Occasionally, if I hit a bump in the road, the sound will also stop.
I'm thinking it could be related to the axle or maybe a calipar is stuck and the brakes are staying engaged. I don't feel a pull in the car, turning is not a problem, and the sound will come and go. I've taken it to the shop, but it hasn't done it for them so they can't tell.
One mechanic said that since there's quite a bit of moisture in the air it could just be water build up somewhere, but that seems odd as I don't think my brakes would cool down that quickly and shouldn't make noise when they aren't being used.
Any thoughts? I don't want my wheels to seize or fall off, bit I don't want to be paying a bunch to have shops look at it if they can't find anything.
