Need some help.
About a year ago I replaced the tires on my 97 Mountaineer with Michelin X terrains. Same size as OEM.
I immediately noticed it was harder to initiate the small steering adjustments we all make when driving. For example, there is resistance to turn the steering wheel when making any minor turn, but then the steering is normal once I get past that little sticking point. I thought maybe these tires were a little more squared off on the edges than my old tires.
I went back to the tire place and they found they did not inflate the tires properly. Adding psi improved the situation but did not fix it. Over the past months I have been playing with the tire pressure and have found this is a factor. I also notice this problem is worse in the am.
Finally, I took it to a mechanic and he said he would check the power steering fluid. After a flush and fill and a "you wouldn't believe what crap came out of that," I feel the problem is better but still not fixed.
Does anyone know if I am looking at a new rack n pinion? Seems strange this all happenned after getting new tires.
