10-10-02, 12:45
Taxlady is offline
Automatic transmission
The Volvo is the first car that I have owned that has automatic transmission. I just noticed that I have adapted a habit from driving standard. I ease up on the gas as the car changes gears. What I'm wondering is if this is bad for the transmission, indifferent, or good for the transmission?
Always do right. This will gratify some people and astonish the rest.
--Mark Twain
10-10-02, 04:12
Frederf is offline
Generally new ATs "learn" from your driving habits. You really shouldn't vary gas when you think you're about to change gears as the AT could learn weird.
I noticed I did this to (MT, AT, now MT again) on my AT because I'm used to getting off the gas when I think a shift is going to happen (even with MT it wasnt' 100% certain  ). Anyway, I never noticed any negative effects of doing this. It might be beneficial due to the fact that the tranny isn't having to shift under load (less stress)? but I have no clue.
10-10-02, 06:55
clint is offline
The modern automatics on proper cars such as volvo have an electronic controller that is connected to the engine's electronic controller to do the same thing you are doing with your foot. The engine torque is decreased during each shift if the controller thinks it needs to be..
I do the same thing though- as if to sort of force the shift to go ahead and happen..
97 A8 4.2 pearl
00 A6 2.7t black
10-10-02, 09:07
Cya, & take the care eh?
4DSC is offline
Originally posted by ejant
If you release the accelerator while the trans is shifting and feel like a lag and then a hard feeling going into the next gear you will eventually wear some parts inside the trans.
ATs are meant for constant application of the accelerator.
Yes, automatics are really mindless-use devices. You're probably just confusing the heck out of the computer when you do it!  Modern transmissions probably shift the smoothest if you just keep constant pressure on the gas pedal and let them do all the thinking.
Brian
10-10-02, 11:15
"That ball wasn't low"
blkZ28Conv is offline
As stated earlier the automatic trans is computer operated and does not require any driver input after the driving demands are interpreted by the ECU. By reverting back to a less efficient manual transmission procedure ( lifting accelerator) you are probably confusing the trans computer analysis and also creating harmful backlash on the drivetrain. Let this modern pierce of equipment do its job. Driving may not be as exciting as with a manual but as in drag racing you will not beat its quickness and smoothness of shifts with a manual( driver activated clutching) or shifting your automatic manually.
Taxlady how do you know when it going to shift or are you lifting after you feel the gear change?  If you are lifting after you detect the gear change you are not effecting the automatic procedure, it is already completed. It seems to me that you are just creating a uncomfortable ride for you and your rider.JMO
Zaino beta tester
10-10-02, 07:18
Taxlady is offline
Actually, I think I only do it when it is in sport mode and I'm accelerating hard. If I don't do it, I feel the kick when it changes gears. I don't feel that kick if I'm accelerating more slowly (which is most of the time).
--Mark Twain
10-10-02, 08:22
The name says it all
caddyman is offline
The transmission shifts gears best with the same pressure, just like in an manual, you matchthe RPMs, but the auto does it for you, it isnt bad, but could wearout your clutches a little bit faster, but i dont it would really hurt anything.
You DO use your parking brake right?
Get out and Detail your car TODAY!
10-10-02, 08:38
Taxlady is offline
Not while I'm driving  Yes I do, even when I stop at the side of the road to let someone out of the car I put it in park and set the hand brake. That's how I knew my hand brake needed to be fixed. What's the hand brake have to do with shifting?
--Mark Twain
10-10-02, 09:21
PAW is offline
Stress on the tranny
When you put the transmission in park, there are prongs or catches that engage. If you let the car roll forwards or backwards, they will have the weight of the car against them. Over time, they can be damaged by this. The proper parking technique with an auto tranny is:
1 - Press the foot brake (the normal brake you use for stopping)
2 - Put the transmission in netural
3 - Apply the parking brake. It can be a hand or foot operated.
4 - Release the foot brake (see #1)
5 - Put the tranny in park
6 - Turn off the car, take the key and leave. Oh yeah, lock the car also.
This reduces the stress on the tranny, specially the park prongs, and will hopefully make it last longer.
10-10-02, 09:22
Shiny Lil Detlr is offline
as long as you arent driving "two footed", you'll be fine.... what annoys me is when someone drives an AT with two feet and the brake pedal is always slightly down, so the CHMSL is always on making me think they're about to stop....
10-10-02, 09:36
Taxlady is offline
I hate foot operated emergency brakes. I had one on my 1971 Nomad with standard transmission. The danged thing could only be let off gently with a foot on the pedal. Really annoying when you have to start a standard on a hill. Drove me crazy. I only have two feet.
I don't bother putting it in neutral first unless I'm on a hill. I leave my foot on the main brake until the hand brake is set. I hate the way it feels when the car rolls and you can feel that it's leaning on the parking pins. If I felt that, I would start putting it in neutral first. Well, I might check that my parking brake was working...
--Mark Twain
10-11-02, 04:06
caddyman is offline
You should get a cadillac, mine automatically releases when putinto gear
I prefer and handbrake, much more control.
