Old 06-03-08, 09:03   #1 (permalink)
JohnnyDaJackal is offline
JohnnyDaJackal is on a distinguished road
Send a message via AIM to JohnnyDaJackal
4 Wheeler Maintenance
Hey guys,
I wasn't sure where to post this thread, but this seemed to be the best fit. Please move if it's not appropriate.
My cousins own property up in the deep woods of PA that they go to maybe every 4-5 months for only a couple days. They own a 94 Suzuki Quadrunner 250 that they bought new maybe 10 years ago. For the past year it's been running progressively worse and worse to the point where we almost couldn't get it started with the pull starter, took about 15 minutes before it finally turned over last time we we're there. Only routine maintenance things they've done is oil and spark plug changes.
Now what one of my patients recommended was to drain the old gas, put fuel stabilizer in it and to get a carb cleaning kit. I'm wondering what are good fuel stabilizer for this kind of application? Will the normal ones at Autozone (Lucas or Seafoam) work? I'm also wondering if there are any other preventative maintenance things that should be done?
Any help from you guys would appreciate. Thanks!
John
2002 Nighthawk Black Pearl Acura RSX
http://www.flickr.com/photos/jackal829/
Old 06-03-08, 09:12   #2 (permalink)
1981 Camaro Z28
BigJimZ28's Avatar
BigJimZ28 is offline
Re: 4 Wheeler Maintenance
run some seafoam through with the gas to help clean it out
then always add sta-bul with the gas(walmart sells it as do most places)
Old 06-03-08, 10:01   #3 (permalink)
Wouldn't be easier to just add more seafoam to the gas since it's also a fuel stabilizer instead of buying another product?
John
Old 06-03-08, 10:17   #4 (permalink)
1981 Camaro Z28
BigJimZ28's Avatar
Sta-bul is like $5 for more then you will use in a year
it works, and I don't mess with what I know works
I put it in everything that I have ever owned that runs on gas and
does not get used that often
I have only used seafoam as a cleaner so I can not tell you if it is any good for a
stabilizer
Old 06-03-08, 12:25   #5 (permalink)
okbeast is offline
okbeast is on a distinguished road
I think it'd be easier/more effective to pull the carb off and clean it w/ carb cleaner, that way you know everything is clean. As far as using seafoam in a quad, never done it. This is on more of a drag bike thoughl
Old 06-06-08, 08:38   #6 (permalink)
Think I'll pick up some seafoam and stabul. I guess I'll throw the seafoam in the gas, then drive it for the weekend to help clean the carb, then I'll take it off and clean it out. Right before we leave I guess I'll add the stabul in and make sure to run it again.
Do you think I need any particular carb cleaner or the cans from Autozone should be fine?
John
Old 06-06-08, 08:45   #7 (permalink)
1981 Camaro Z28
BigJimZ28's Avatar
IMO carb cleaner is carb cleaner
Autozone is fine
good luck
Old 06-14-08, 03:40   #8 (permalink)
spike_africa is offline
spike_africa is on a distinguished road
Pull the carb off and just clean it out real well. Might need to unscrew the jets out and clean them up so you can see threw them and the needle might need to be taken out and cleaned up. If it sits for a long time **** will build up and make it run like ***.
2002 GT Mustang 5speed
-sprayed,drag radials,powershifted every day
Juggling "regular" job and maintenance details..... kleraudio Professional Detailer General Discussion 8 07-03-07 04:58
honda owners ; i need maintenance advice beefy z Car & Driver 7 04-10-07 07:00
Basic Car Maintenance Guest Car Ownership 0 11-20-06 04:13
New car choices - maintenance costs? 2wheelsx2 Car & Driver 19 01-23-03 09:20
Maintenance for your PC 7424 SJ Car Detailing 6 01-13-03 01:24
