04-28-08, 07:36
#13 (permalink)
e46 m3 is offline
Join Date: Jul 2007 Posts: 3 | Re: The 32k Question S4, M3, ect? Quote:
Originally Posted by Shuskan3 Go drive an E46 M3 and your decision will be easily made... | it drives VERY well, and it's sexy.
plus there's an abundant aftermarket for it.
aside from the blatan bias by my username, i think they look sexier too:  | |
04-28-08, 10:01
#14 (permalink)
| | Ari Gold
G35stilez is offline
Join Date: Jul 2003 Location: Southport, CT Posts: 6,543 | Re: The 32k Question S4, M3, ect? E46 M3. I looked at both and if it were for *me* with my goals for a vehicle nearing a close parallel to yours, an M3 is almost an "obvious* choice.
Regarding snow, if you can track your car, you can drive it. With snows and 18s, it wouldn't be that hard.
Find a CPO'd example in the colours and tranny you want and pull the trigger.
__________________ 2006 DG|G Infiniti G35 Sedan | 6MT (SOLD) | |
04-28-08, 03:07
#15 (permalink)
| | Warm weather is back!
kaval is offline
Join Date: Apr 2007 Location: Toronto, Ontario Posts: 502 | Re: The 32k Question S4, M3, ect? Given your requirements, I would go with the S4. It's a very comfortable car, extremely pracitical and would be a blast to drive in the winter with the Quattro system. Also, it would be cheaper on insurance given the sedan setup as opposed to the 2 door of the M3. M3's just aren't as practical.
As for the track, the M3 would be a lot more fun IMO, but it's hard to compare the two since one is RWD and one is 4WD.
I'd say to go drive them both, beat the hell out of them and then decide. | |
04-29-08, 11:50
#16 (permalink)
| | Swirlophobic
whitejavaS500 is offline
Join Date: Oct 2005 Location: South Shore, MA Posts: 446 | Re: The 32k Question S4, M3, ect? Quote:
Originally Posted by Surfer I'll say used CTS-V. S4 is borring in comparison to the E46 M3 and especially CTS-V. Plus the CTS-V is easily modified for power and great on track. But then you have to decide if you really need awd for winter though. | Ehh, my neighbor has one, and quite honestley, I can say IMHO its a POS. Just feels like its "loose" and unconnected.
Ben
Spotless Auto Reconditioning
Marshfield, MA
04-29-08, 04:13
#17 (permalink)
Surfer is offline
Join Date: Jan 2006 Location: Boca Raton, FL Posts: 476 | Re: The 32k Question S4, M3, ect? Quote:
Originally Posted by whitejavaS500 Ehh, my neighbor has one, and quite honestley, I can say IMHO its a POS. Just feels like its "loose" and unconnected. | I actually thought it drove better then e39 M5. I almost bought e39 M5 including my buddies Dinan S2 that was awesome but the V really impressed me and so easy to mod. | |
05-01-08, 08:00
#18 (permalink)
BuffMe is offline
Join Date: Oct 2007 Posts: 432 | Re: The 32k Question S4, M3, ect? M3 looks great, but the interior is.... bleh. The perfect choice for me would be an M3 exterior/engine with an S4 interior. | |
05-07-08, 09:45
#19 (permalink)
orionredwing is offline
Join Date: Feb 2008 Posts: 29 | Re: The 32k Question S4, M3, ect? E46 M3 is a great car, but also consider the E90 (Sedan) / E92 (Coupe) 335i. I see some great deals on craigslist, but $32K is still the exception, not the norm for 335is atm. E46 M3 will handle better, but the 335i is the rave (easy tune at not much $$). You can read up on the 1000 comparisons between the 2, but the 335i is definitely a strong recommendation. | |
05-07-08, 10:04
#20 (permalink)
| | Practical Perfectionist
Join Date: Sep 2002 Location: NE Ohio Posts: 19,034 | Re: The 32k Question S4, M3, ect? Quote:
Originally Posted by orionredwing E46 M3 is a great car, but also consider the E90 (Sedan) / E92 (Coupe) 335i.. | Do those come with limited-slip diffs? I'm not Bimmer expert, but IIRC a lot of them have stability/traction systems instead of a real LSD. | |
05-07-08, 12:29
#21 (permalink)
Join Date: Feb 2008 Posts: 29 | Re: The 32k Question S4, M3, ect? You're correct. The 335i only comes with an electronic differential (traction/stability control) which applies braking power (not torque xfer) upon slip. So on the track, the E46 M3 w/ LSD and M suspension out handles the 335i imo. However, if you're mod friendly, the E90/E92 chassis is stiffer (gradual improvement of each generation), and the potential of the twin turbo is huge. E.g. Depending on the tune, $1500 (as low as ~$500) will yield an easy ~60HP ~80LB-FT of improvement (we're talking 0-60 in ~4.3s). Add some coilovers, and you'll be trying to chase (not beat) the current generation M3, instead of following behind last generation's.
Lastly the OP wants a 4 seater, and the high torque (in the low RPM range) of a twin turbo makes it a great daily driver. You won't have to rev it up to screaming proportions on the street like you do in an M car. Quote:
Originally Posted by Accumulator Do those come with limited-slip diffs? I'm not Bimmer expert, but IIRC a lot of them have stability/traction systems instead of a real LSD. | | |
05-07-08, 02:07
#22 (permalink)
Picus is offline
Join Date: Aug 2005 Location: Toronto, ON Posts: 2,816 | Re: The 32k Question S4, M3, ect? An LSD for an e92 coupe is $1600 for internals, ~$2200 for the full pumpkin. I have the internals (BMW started welding the diff after March 07 production). My tune was $900, got me 68hp and 81lb/ft of torque. Cat back only netted 11hp and 12lb/ft of torque. Not sure on downpipes, no dyno since then.
GTA In Detail
05-07-08, 02:24
#23 (permalink)
| | ~werd to yo mutha~
Way2SSlow is offline
Join Date: Mar 2005 Location: Alpharetta, GA Posts: 1,323 | Re: The 32k Question S4, M3, ect? I've driven both..I dont have a ton of wheel time in it, but if it were ME......living in GA with no snow....M3. If I'm having to deal with snow...S4.
94 Impala SS in the ONLY color
04 Ford Focus ZX3 in white (daily driver)
~werd to yo mutha~
Wade----- Gallery | |
05-08-08, 08:33
#24 (permalink)
Join Date: Sep 2002 Location: NE Ohio Posts: 19,034 | Re: The 32k Question S4, M3, ect? Picus & orionredwing- OK, sounds like the aftermarket has the diff issue covered. Just seems odd to me that BMW doesn't offer them on some models
And yeah, certain turbo setups work great, though I'm usually sorta a naturally-aspirated guy myself. | |
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests) | | mborner | | Thread Tools | | | | Display Modes | Rate This Thread | Linear Mode | |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | All times are GMT -7. The time now is 09:17. | | | |
