01-05-08, 03:24
#25 (permalink)
Jek Hawkins is offline
Re: Honda Accord V6
congrats on your excellent choice! Have you decided coupe or sedan? in town recently i've seen a white sedan and a black coupe and a red coupe, and i have to say the coupe in black is absolutely stunning! performance-wise, Road & Track liked the car a lot-performance was not AMAZING, but pretty good for a family car
EXHILARATING THRILL + 34 MPG = INTEGRA
01-05-08, 03:35
#26 (permalink)
3wide is offline
Re: Honda Accord V6
one thing you might want to be aware of. i don't know about the 08 accords but previous years used a timing belt to run the engine as appose to a timing chain many other v6's use. the bad part of useing a belt instead of a chain is the belt needs to be replace every 60,000 miles or so. it's a big job with alot of labor = big $$$. i wouldn't let it change your decision if they're still using timing belts but you should be aware of it.
For some reason i didn't think a black car would be that bad...
01-05-08, 03:46
#27 (permalink)
Setec Astronomy is offline
Re: Honda Accord V6
Chains FTW! The Sonata has a chain, not sure about the Accord. Unlike 3wide, I consider that a major factor that I always check on.
Grumpy like Ketch...
01-05-08, 06:07
#28 (permalink)
I don't have much to add
SpoiledMan is offline
Re: Honda Accord V6
The belt needs changing every 105k miles. When the belt was changed on our Honda van is was still in awesome shape. I really wouldn't worry about that.
Black cars are fun!
01-05-08, 06:09
#29 (permalink)
Re: Honda Accord V6
Holy crap! Honda's got the timing belt change interval up to 105K miles?
01-05-08, 06:24
#30 (permalink)
paul34 is offline
Re: Honda Accord V6
Hmm, I wasn't aware there were still modern-day automakers still using belts! I thought most had caught up with the times and were using chains now. At the very least, Honda. Hopefully they are using a chain on the 08.
I will say that I've driven many an Accord, and also a few 08's - my god are the interiors wonderful! Among the best, for sure. The ride is so good for that type of vehicle. Steering is relatively very good, and suspension is not boaty at all, but is not harsh either.
Interior really makes you feel relaxed and good. I'd definitely recommend it.
ONR = Optimum No Rinse
01-05-08, 06:41
#31 (permalink)
Re: Honda Accord V6
Mike they were 90k in the early 90's.
Black cars are fun!
01-06-08, 05:14
#32 (permalink)
Not too old to learn.
RTexasF is offline
Re: Honda Accord V6
Honda I4 has the chain the V-6 still uses a belt. Both are superb engines.
01-06-08, 06:29
#33 (permalink)
jswift2000 is offline
Re: Honda Accord V6
I believe the timing belt change is at 105,000 on the honda V6 engines. Thats when my 2000 Accord suggusted the belt be changed and my 2007 TL suggests the same thing or later.
01-06-08, 06:51
#34 (permalink)
Re: Honda Accord V6
105K isn't bad...I'd still rather have a chain!  on the 60K intervals.
01-06-08, 07:40
#35 (permalink)
mrmatt is offline
Re: Honda Accord V6
I decided that I want the accord sedan. I'm going from a Toyota Tacoma to a Honda so this should be an interesting change. As for color I'm having a tuff time making up my mind on what to pick!
01-06-08, 08:22
#36 (permalink)
Trying Hard
tabinha is offline
Re: Honda Accord V6
If you are a driver. Get the V6.
Good luck
Harv.
Harv
