I read the info about it, it has "space age polymers" (hmm another blackfire/platinum products thing?). Anyway, here is a few captions from the info they provide.
Tire rack says
"Wheel Wax is different from wheel polishes because it is not a polish, it is a wax formulated with space age polymers and resins, a heat resistant sealant and
carnauba wax, which provides the ultimate protection for wheels. There are no ingredients in Wheel Wax that are harmful to wheels or their finish. Wheel Wax is treated to provide long lasting protection and formulated for ease of application.
Just wipe on, let dry to a haze and wipe off. For maximum shine, rinse with cool water and buff to a high shine. After 24 hours, Wheel Wax changes the surface polarity of wheels to repel the brake dust and makes the wheels easier to clean. Wheel Wax is also designed to help combat the effects of road salt and harsh winter road chemicals used in the Snow Belt, however whenever contaminates get on wheels they should be removed as soon as possible to keep wheels as new looking as possible.
The sooner Wheel Wax protective treatment is applied to new wheels, the longer the wheels will stay in like-new condition. After applying Wheel Wax, clean wheels every week using only neutral pH
car wash soap. In many cases you may only need to use a soft, damp, cotton towel to get the best results.
Wheel Wax was formulated to last longer on wheels then any other product on the market; however, the lasting power of Wheel Wax will depend on how often the wheels are cleaned, and what product is used to clean them. If wheels are cleaned on a regular basis with water or neutral pH car wash soap, Wheel Wax should be applied every month. If any other chemical, high pH soap or automatic car wash is used, then Wheel Wax should be applied after each wheel cleaning."
Sounds like any other polymer, #20 and
AIO, etc.. Anyway has anyone tried it, I wonder if it really is "specially formulated"
