Originally Posted by BMW335i What is the most popular engine dressing treatment on this board?? |
I'm going to have to say that CD-2 is one of the most praised engine dressings around here... but there are so many... just take a look around
Originally Posted by mikebai1990 paul34, thanks for the thorough writeup. I'm slightly more inclined to do an engine detail now. Before I was pretty scared because I'm afraid I mess up some internal engine parts. So as long as I cover up the alternator, I should be okay?
Curious about the battery terminals too. |
Yea, I was really scared too, but one night of some unintentional mudding forced me to just take a chance.
And yes, you should be ok on any modern car. In fact, I don't even think a lot of the pro detailers here even cover up the alternator, but I do it just to make myself feel a little better I guess
. No, but the pro detailers around here tend to use pressure washers which isn't all water but also has a large amount of air - no doubt a way to effectively clean without trapping water in places where it shouldn't be.
I just free-flow rinse to try to eliminate trapping possibilities (also why I use the leafblower then immediately turn on the engine and allow it to get hot so any water is completely dried away).
About the battery terminals... yea, I wondered too, but I had mud all over it (and even in the little plastic tray it sits in) and knew it would be next to impossible to clean up with a towel and ONR. I just took a chance... and nothing happened! Yup. Got hit with APC and my mix of dishwashing soap and water, and of course plain water. Nothing happened to it... Of course, I don't keep it soaked in water... I try to dry it up a bit with the leafblower.
I think as long as you don't go blasting water into components you should be ok! Just take it slow, and remember at the end to turn the engine back on as quickly as possible. Just make sure you took your stuff and family members out of the fans and belts
Originally Posted by Por2geezSupra Ok, thanks fot the write up. Do you cover up the battery terminals, or even the battery when you do it? Also, do you usually just do 4 cups of megs apc to one cup of water? Is that how you usually measure it when you do it? |
No I don't cover the battery. Well, what I did was I have these Rubbermaid spray bottles... 32 oz. I just calculated the ratio according to that and filled accordingly within the bottle.
It's just 4:1 of whatever measurement you use. It could be 4 gallons of water to 1 gallon of APC, or one oz of apc to 4 oz water, or one martian fort knox edition cup of major doom... well, you get the idea
