Hello all. The guys over at acurazine told me to come over here and ask this. Long first post, but here goes...
I try to keep my TL in pretty good shape. I clean the paint, polish, and wax it roughly 2-3 times a year. Recently I washed my car and started to noice really bad
water spots on it. Since there is a good bit of wax on the car, water usually slides right off, but not this time. I dried the car about 5-10 minutes after I washed it, and these spots occurred. This was done about 6pm with around 70-75 degre temps.
Fast forward about two weeks, and I wash the car again. This time, it looks absolutely horrible. The entire car is covered in water spots. Every piece of chrome, the paint, the windows...everything. It almost looks like the car is covered in spotty dirt.
I live in an apartment complex and I believe either they or the city started adding a chemical to the water (possilby chlorine). The water here is really hard and I have a major problem keeping glassware/coffee pots etc from not having hard water stains.<br />
I've tried nearly everything I can do to remove the water spots. I used stoners glass cleaner, along with some el cheapo foaming cleaner, and even distilled vinegar and nothing has worked so far on the windows. The same holds true on the paint of the car. I've tried
meguiars paint cleaner (step 1) and I get the same results. Even with the polish (step 2) I can still see the spots.
I just washed the car again yesterday, hoping that they would wash out, but still nothing.
What can be done to fix this mess? I've got a few pictures here. Maybe you guys can tell what I need to do or what may be causing this? It's kinda hard to take pics of this, so bear that in mind.
The chrome...
Window (without flash)
Window (with flash)
Paint (above the
headlight, look very close and you'll see brownish spots
Paint (above the drivers fender, looks like streaks)
HELP!
Today I sprayed the front end with a distilled water/70% alcohol/distilled vinegar mix. After wiping the car, it was removing a browish/orange oxidation. You could litterally see the change in the paint (and the dirt coming off). After this, I applied
Meguiars paint cleaner, then Meguairs Crystal Polish, then clayed the entire front end. After all of this, I waxed with
NXT. Every streak is gone and the paint looks a lot better.
The paint afterwards (taken in the dark)
Above the light
The chrome
I also used Meguiars PlasticX on the
headlights (and the chrome/plastic grille) and got fantastic results. If you look close, you can still see some of the original chemical residue, but overall it is a 99% improvement.
My only problem now is the rest of the car...and the windows. Nothing is getting the spots off the glass. Suggestions?
