Originally Posted by mwe2121 Hi I've already purchased the klasse twins and have been reading the post about applying the KSG and buffing off. I have read diffrent post about using sonus product that is now discontinued to aid in buffing off the KSG. My question is should I get sonus Acrylic glanz, Sonus Detailing Spritz or should I get both.
Thanks,
Matt |
Do you mean buffing off the KSG with a machine or by hand? Unless you are a pretty much an expert with the buffers,
SG is probably better done by hand. There still can be a hazing problem (which requires hand buffing) if you apply too much but thin application will avoid this. If you do have to buff out the haze, I suggest a Sonus-like mixture of 1 part SG to 3 parts distilled water. Put it in a mister bottle and squirt the haze, then buff with a mf - the haze should come right off.
Good QDs like
Menzerna's HGAS,
Wolfgang's spritz, Jeff's SG as well as of course the Sonus, should work for this as well. But if you have a bunch of SG and some distilled water, this method is the most economical way to go.
