04-16-06, 01:06
| | CARdiologist
Beason is offline
Join Date: Jun 2003 Location: Louisiana Posts: 947 | Buffer Trails from Hell I was recently in a wreck and had my front end particaly redone. My hood was repainted after a dent was hammered out and noticed today in direct sunlight that there are buffer trails all over it. How hard is it to remove them with a PC? My strongest products are SSR2.5 and DACP. The shop said it takes 60 days to cure so I have time to get products if needed. | |
04-16-06, 01:19
roadmaster_Tx is offline
Join Date: Jun 2005 Location: houston tx Posts: 392 | its not too hard, just make sure u wash and clay the vehicle properly and use a pc. You have the right polishes. Make sure you work the polishes in completley. | |
04-16-06, 01:40
| | CARdiologist
Beason is offline
Join Date: Jun 2003 Location: Louisiana Posts: 947 | Quote: |
Originally Posted by roadmaster_Tx its not too hard, just make sure u wash and clay the vehicle properly and use a pc. You have the right polishes. Make sure you work the polishes in completley. | Are they basically like removing swirls? | |
04-16-06, 02:25
| | Pinnacle Detailing Owner
GregCavi is offline
Join Date: Aug 2004 Location: Rochester & Lake City, MN Posts: 1,921 | hit it with the lightest polish first. THey arent always the hardest to remove. Start with maybe an SSR1 if you have it, and if it doesnt cut it (literally!) then move up. My product of choice woudl be either menzerna FPII or optimum polish.
Greg | |
04-16-06, 04:34
| | Practical Perfectionist
Join Date: Sep 2002 Location: NE Ohio Posts: 20,886 | I wouldn't necessarilly wait for the paint to finish curing, as it'll be harder then. I've done it both ways, and unless the fresh paint is so soft that you keep micromarring it, I'd probably fix them now (especially since you're not using a rotary).
Buffer trails are the classic example of "swirls"; actually, these are the only *truly accurate* use of "swirls", it's what the word really refers to to those of us who care.
Just another form of marring, like light scratches. Sometimes they're a pain to get out, usually a) on hard paint and b when there was heat involved with putting them *in*. But quite often they're not that hard to polish out.
I'd expect the #83, followed by something milder, will take care of them. But yeah, you might try something milder first and see if that'll do it. | |
04-16-06, 04:54
gbackus is offline
Join Date: Feb 2004 Location: South Gate, CA Posts: 576 | I agree with accumulator. Fix it while the paint is soft, as the paint may harden to a point that the buffer swirls will only come out with rotary use. | |
04-16-06, 05:44
| | CARdiologist
Beason is offline
Originally Posted by gbackus I agree with accumulator. Fix it while the paint is soft, as the paint may harden to a point that the buffer swirls will only come out with rotary use. | Will the paint still be soft in a month? | |
04-16-06, 05:50
| | Now with twice the head
Join Date: Oct 2001 Location: Arlington, TX Posts: 25,616 | They buffed with a rotary already right? Totally safe to use the PC to remove their buffer trails. I'd go with DACP and follow with #80 since #80 leaves a new paint safe layer of polymer protection. | |
04-16-06, 06:08
| | CARdiologist
Beason is offline
Originally Posted by Scottwax They buffed with a rotary already right? Totally safe to use the PC to remove their buffer trails. I'd go with DACP and follow with #80 since #80 leaves a new paint safe layer of polymer protection. | #80 is speed glaze correct? How long should I wait till I wax it after buffing? It was only painted wed. | |
04-16-06, 06:11
UnsanePyro is offline
Join Date: Sep 2004 Location: Rhode Island Posts: 364 | Ihave the same problem actually.
I spoke with someone from Poorboys, and they said that the SSR line is safe to use on fresh paint. I used a little bit of SSR1 with a hand applicator to try it out, and it worked great, and that was a few weeks after the repaint. | |
04-16-06, 07:25
gbackus is offline
Join Date: Feb 2004 Location: South Gate, CA Posts: 576 | Quote: |
Originally Posted by Beason Will the paint still be soft in a month? |
That depends on how they mixed the paint, if they added hardeners, what ype of paint, brand, etc.
I've had paint come out both ways, really soft at first and then it becomes rock hard and almost unpolishable, or it stays so soft that breathing on it will mar the paint.
I can count on one hand how many repaints I've come across where the paint is right in the middle. | |
04-16-06, 09:06
Join Date: Oct 2001 Location: Arlington, TX Posts: 25,616 | Quote: |
Originally Posted by Beason #80 is speed glaze correct? How long should I wait till I wax it after buffing? It was only painted wed. | Wait however long the body shop says to wait before waxing. They should know their paint better than anyone else.
#80 is Speed Glaze. | |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | All times are GMT -7. The time now is 06:26. | | | |
