02-04-02, 05:47
| | Reformed Carnuba-Sniffer
SouthernBoy is offline
Join Date: Jan 2002 Location: Columbia, SC Posts: 146 | Swirl removers - abrasive vs. chemical A buddy of mine stopped by this weekend after I BF'd my car. He drives a red early 90's vintage BMW. He has always waxed the car so the paint is in good shape. He wants me to help him duplicate the shine he saw on my car  .
By reading through the old posts, I know that there are chemical, abrasive and chemical/abrasive swirl mark removers. The swirls on his car are not the worst I've seen, but you can see them in virtually any light.
So that brings a technical question to this newbie's mind...
The swirls are too bad for just the BF polish, but I'm confused as to what swirl mark remover can be used before the BF polish?? Will a chemical SMR be removed by the BF polish??
BTW, I (he)  will be using a PC for all applications.
Any help appreciated.
"I have not failed. I've just found 10,000 ways that won't work."
- Thomas Alva Edison (1847-1931)
02-04-02, 05:55
| | Missing In Action
puterbum is offline
Join Date: Oct 2001 Location: San Diego AIM:sdputerbum Posts: 1,616 | I don't believe there are any chemical swirl mark removers besides a urethane paint thinner (joke). Any swirl remover that actually does as it says and removes swirls will have to abrasively remove a thin layer of paint from the car or chemically strip a layer of paint off the car (not recommended at ALL).
Are what you referring to as chemical swirl removers ones with fillers that hide the swirls?
3M Swirlmark Remover #39009 for dark cars should work fine by PC and some pressure -- it removed swirls by hand for me. If that with some pressure doesn't work, try Finesse-It II or PI-III.  | |
02-04-02, 05:57
joed1228 is offline
Join Date: Mar 2001 Location: MA Posts: 1,932 | I would think it depends. There is the swirl mark remover that hides the swirls and the ones that remove the swirls.
If you used something from the Meguiars product line that hides the swirls the BlackFire polish may remove the Meguairs product.
If you use a 3M swirl mark remover for example you are actually "fixing" the swirl's by filling them in with clearcoat. The BlackFire would not remove the 3M product because there really isn't any product left "on" the paint. The product that was used fixed the swirls, it did not hide them.
Hope you can understand my babble, not good at explaining this type of thing.
Boston, MA auto detailer.
http://community.webshots.com/user/cleancamarojoe
02-04-02, 05:57
Join Date: Jan 2002 Location: Columbia, SC Posts: 146 | Are what you referring to as chemical swirl removers ones with fillers... Yeah, I should have been a little more specific on the "chemical" term.  You hit it on the head, I was referring to fillers.
02-04-02, 06:00
joed1228 is offline
Join Date: Mar 2001 Location: MA Posts: 1,932 | I know Zanio makes a "filler". It's basically those natural products that claim no abrasive stuff in thier prouct. Without something to smooth the clear coat over the scratch (what a swirl mark is) all your doing is filling the swirl with a product that fills it to make the surface even which will have to be re-applied sooner or later.
02-04-02, 06:04
Join Date: Jan 2002 Location: Columbia, SC Posts: 146 | Which PC pad should I use? Quote: Originally posted by puterbum 3M Swirlmark Remover #39009 for dark cars should work fine by PC and some pressure | If I'm using the PC with the 3M SMR, do you think I should use the yellow or white CMA pad?
02-04-02, 06:13
joed1228 is offline
Join Date: Mar 2001 Location: MA Posts: 1,932 | The product your going to use is very very mild. The yellow pad is sort of "needed" to get results.
I dont know if you want to use the method I use but I have been detailing with the buffer for almost a year now and I found this process to work the best.
Use the buffer to work the product in (a little pressure), moving in lines at a rate of around 3 inches per second, the second pass use less pressure and move the buffer a little faster. I move the buffer over the area four times, by the fourth time I am hardly using any pressure, the buffer is spinning freely and the product is hazing as the buffer is leaving it's trail. I then buff it off and have a huge smile on my face.
02-04-02, 06:15
| | Missing In Action
puterbum is offline
Join Date: Oct 2001 Location: San Diego AIM:sdputerbum Posts: 1,616 | I'd like to add a bit here . . . 1) 3M swirlmark remover both removes clearcoat at the edges or a swirlmark AND leaves behind fillers.
Magnified view of a deep swirl mark before an abrasive:
|_|
AFTER:
\_/ (lesser angles)
They round off the edges of swirl marks and light scratches until they are either invisible or very hard to see (2 apps of properly applied SMR should remove all of the normal swirls).
Dawn wash after SMR, it leaves some mild fillers behind. You'll know you got them all when water stops beading on some spots on your car.
I'll leave the PC stuff to other people . . . | |
02-04-02, 06:16
Join Date: Jan 2002 Location: Columbia, SC Posts: 146 | Quote: Originally posted by joed1228 ...I dont know if you want to use the method I use but I have been detailing with the buffer for almost a year now and I found this process to work the best... | I like it, I like it!
Man, my buddy's going to have some tired arms by the time "we" finish!
02-04-02, 06:19
Join Date: Jan 2002 Location: Columbia, SC Posts: 146 | Dawn wash after SMR??? Hey puterbum, is this to give the BF polish a clear shot at the paint? In other words, remove all the chemicals from the SMR to prevent streaking?
BTW, thanks to you and joed1228 for helping.
02-04-02, 06:20
joed1228 is offline
Join Date: Mar 2001 Location: MA Posts: 1,932 | Oh wow, thanks for the info Pete. So what your saying is follow-up every two layers of the SMR with a wash to see how many swirls you REALLY got rid of?
That's going to be a major pain in the but with my car since it's so hard to dry but I'm going to go the extra mile. I am trying to make a time table since it takes me so long to detail my car.
I can use the clay and swirl mark remover on friday, the Klasse All in One on Saturday and all Day Sunday with be for the Klasse Glaze.
02-04-02, 07:00
| | Detailing Waterboy
Yell00ITR is offline
Join Date: Jul 2001 Location: Chicago, IL Posts: 281 | You dont necessarily need to wash. Just keep a spray bottle handy with 50/50 isopropyl alcohol/distilled water. After buffing, mist a section and wipe clean. You will strip any fillers and be able to see if you need to perform more abrasive work. | |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | All times are GMT -7. The time now is 06:58. | | | |
