My 96 Explorer had moldings running down each side, so I decided to take them off for a cleaner look, but on the drivers side I discovered a problem. It looks like in the past the vehicle had some body work done from an accident and had the clear resprayed. Once I took of the molding a line of the new clear from the edge of the molding was visible as you can see in the photo below (clearcoat edge line is right under the door indentation in the center, line is most visible on the right side of the photo. this was the best photo i could get!). So I was wondering if this line can be blended in by wetsanding, so it is not as noticeable.
My plan of attack was to wetsand with maybe 2000 to smooth out the line and then follow up with a compound with wool pad on a rotary and the polish it out. Since this would be my first wetsanding attempt, my questions are:
1) For all you wetsanding experts, would I be able to blend this line successfully by wetsanding, and which grit(s) paper would you recommend?
2)Which of these 2 brand compounds would you choose to tackle the sanding marks. I was looking at either the Optimum Hyper Compound or one of
Meguiars?
3)Any other tips, opinions, or recommendations for someone wetsanding something like this for the first time. I have had this truck for about 6 years, so this clear coat is probably a little older then that.
thanks for all the help
