I've got a dark silver car (titanium silver). The finish is virutally brand new (only 6K miles and pampered). I think someone keyed it as I discovered a deep scratch about 18" long that goes across part of the side panel and over the gas cap. Boy was I pissed. To have the best shop in town repaint where you can't tell, I'm looking at $1K - they do an amazing job (they'd paint essentially half the entire side of the car - you get what you pay for). OUCH.
I stopped by the best detail shop in town and as a courtesy they ran a rotary over it for about a minute or two and lessened it some. They recommended a paint repair shop as an alternative to the high-priced body repair shop. I visited them, the owner said the scratch is just in the clear coat but is deep enough that it cannot be completely removed (you can feel it easily with your fingernail). He said they could probably get a little more aggressive than the detail shop and do some light wet sanding and buffing to reduce it further.
So I take the car in and an employee of the paint repair shop simply spends another five minutes with a rotary. I spoke to him on the phone about the wet sanding, but he didn't do it, and after he did the polishing he said, ya we can wet sand it, primer, and paint it. Primer and paint it? Huh? I just sort of assumed he determined all he could really do is polish it. I should have asked more questions. I think because of the condition of the car, he was afraid he was going to mess up my clear coat if he did anything more agressive. I've yet to talk to the owner whom I originally discussed this with.
One thing is that 50% of the scratch is on the gas cap. So I COULD buy a new gas cap and have it painted and have 50% less scratch. But I was also thinking, the gas cap would be a perfect place to see if I could lessen the scratch. I have basic detailing experience but have not used a rotary before but understand the risks and techniques. I've got the PC that is the random orbital.
I'm tired of taking the car to the shops (I still probably should contact the owner and ask why his employee didn't do the wet sanding and buffing/polishing he spoke of). In the event I try to buff out the scratch on the gas cap myslef knowing I can get a newly painted cap if I screw it up. What process would people recommend to lessen the scratch. I'm not sure even what grit to use. I've got one of those
meguiars red pads you can put on a drill to use as a rotary polisher (ya, I know, crude and I can see people cringing, but I'm not going to go by a rotary just for this one repair) and then can use my PC orbital to polish.
Before resorting to trying to essentially remove a thin layer of clear coat to lessen the scratch I figured I should see how well I can hide it. After he buffed it, it was pretty hard to see except in sunlight. Last night, I polished it with some 3M Swirl Remover for dark colored cars since the product is a dark grey then put some
Klasse SG over the top, let it set for an hour and polished it. It appears I made the scratch MORE noticeable as it has a definitely white color in the clear coat instead of being, well, clear. I'm almost thinking I should try taping the scratch off, sparying it with touch and clear coat and then buffing it out, in other words, trying to fill in the scratch with just a tiny bit of the titanium paint enough to make the scratch dark instead of light. But I realize that's probably a foolish idea to think that would make it LESS noticeable??
So my question is two part:
1) What do people recommend as the best process to try to hide it. Does that colored scratch hiding product either in grey or black you see in the Auto Parts store work as long as I'm willing to apply after every wash or should I stick to a combination of other products?
2) If I decide to try to lessen the scratch on the gas cap using a more agressive approach than just buffing, what process do people recommend?
Thanks in advance.
