Old 01-29-02, 11:17   #1 (permalink)
tmchow is offline
tmchow is on a distinguished road
Apply Zaino in CIRCULAR motions?!
I'm reading the application guide on the Zaino website and noticed it says:
"Squirt a dime size dab of polish on your applicator and rub it into your paint using circular hand motions"
Is this correcT? I thought it all waxes and polishes were supposed to be applied AND buffed out in back and forth motions (front to rear)?
Old 01-29-02, 11:25   #2 (permalink)
geekysteve's Avatar
geekysteve is offline
Location: Interested in product performance - not popularity contests
geekysteve is on a distinguished road
Might be a slight misunderstanding - the ZFX/Z5/Z2 mix directions indicate to apply first in a circular motion, then finish with back and forth motions.
I believe it has something to do with activating the ZFX - Z1 needed to be applied in a circular motion, and while I don't know anything about the Zaino formula, I suspect a slight amount of heat might be necessary for the ZFX (or Z1) to activate? Thus the circular motions first...this is _strictly_ my own theory about the circular motion.
If you're using a high quality applicator, and the surface is clean & free of grit/contaminants, some circular application should be ok.
Hope this helps.
Old 01-29-02, 11:27   #3 (permalink)
Under Pressure
laynlow's Avatar
laynlow is offline
laynlow is on a distinguished road
Send a message via AIM to laynlow
If you read the tips and tricks section on their site, it also suggests a front to back (read bumper to windshield) motion on all horizontal surfaces, and a top to bottom motion on all vertical surfaces. That method is supposed to enhance the way the car reflects light resulting in better shine.
Either method will work I suppose, but I used this method with excellent results. As long as your applicator is not scratching the surface, and you get a nice smooth even coat, I think you will be just fine.
Old 01-30-02, 12:14   #4 (permalink)
Z#11 - K#4
William420's Avatar
William420 is offline
William420 is on a distinguished road
Zaino site says to rub using circular hand motions then go over same area using straight back and forth motion on top panels, and an up & down motion on side panels. I believe the purpose of using circular motion first then going over again at different direction is to maximize the coverage. I don't think "heat" is required to activate Zaino as that's what ZFX is for. (heat is required for Zymol )
Personally I do not follow this instruction and just do up & down / straight back & forth.
Old 01-30-02, 10:02   #5 (permalink)
Senior Moderator
DETAILKING's Avatar
DETAILKING is offline
William is correct......
It is too insure maximum and complete coverage. Go circular and finish up back and forth......
Old 01-30-02, 10:10   #6 (permalink)
geekysteve's Avatar
Heat
As I understood Sal from an earlier phone call (months ago), the Z6 is heat activated, and the buffing action from the towel activates the Z6. Just thought the ZFX might require something similar.
Thanks for the info gentlemen!
Old 01-30-02, 10:18   #7 (permalink)
MikeLS's Avatar
MikeLS is offline
MikeLS is on a distinguished road
Post
I've always applied Zaino either back/forth or up/down motions, no circular. You get the same coverage doing that as you will circular and it minimizes the possibility for swirls. Plus, I think it looks better too....
Hmmm, Z6 heat activated? I never rub Z6 in hard enough to generate any heat.
Old 01-30-02, 10:58   #8 (permalink)
Senior Moderator
Brad B.'s Avatar
Brad B. is offline
Brad B. is on a distinguished road
Always back and forth with abrasives. Circular for maximum coverage with final non-abrasive waxes and sealants. Remember, use light application pressure for final coats.
2005 Audi S4, 1996 Porsche Carrera C4S, 1972 BMW 2002tii, 2004 BMW M3.
Old 01-30-02, 11:05   #9 (permalink)
Insert joke here ________
Guess My Name's Avatar
Guess My Name is offline
What they William, DK and Brad said!
Neat Vehicle Freak
My Truck Album
2002 Chevy Avalanche
Can you apply zaino right over 3M perfect it? deputydog95 Car Detailing 3 03-28-02 06:05
What to apply and remove Zaino Z2/Z5/Z6 with? tmchow Car Detailing 8 02-07-02 04:06
Can't apply more than 3 coats of Zaino with Zfx? tmchow Car Detailing 4 01-30-02 11:39
How do you apply Zaino Z-9 and Z-10 to leather? 2500HD-Vortec Car Detailing 1 11-16-01 07:46
Where on a BMW can I apply Zaino Gary Car Detailing 8 10-25-01 10:16
