I don't like the idea of applying that much force to the dirt on my vehicles even if it *is* just shampoo or water. So I never use my pressure washers for this. I know plenty of people do though and if it works for somebody that's cool with me (not saying my method is the only way to go).
The safest way I've found to remove serious dirt (like what gets built up in the winter if you don't wash very often) is to use a foamgun in conjunction with a high-quality BHB. Use a strong shampoo mix. Shoot the foam through the bristles of the BHB while just barely contacting the surface of your panels (not hard enough to really bend the tips of the bristles). Move the BHB *just a little*, sorta "rocking" or "jiggling" it on the paint while still just *barely* contacting the panel. *DO NOT WIPE WITH THE BHB LIKE WITH A NORMAL WASH TECHNIQUE* That would cause marring. Just work the BHB across the panel by picking it up off the panel and setting it back down, rocking it the whole time. I raise it up and rinse it (using the foamgun) every few inches even though I hardly ever see any dirt on it. It takes more than one of these light passes to get all the dirt off so plan on going over the panel a few times- exercise self-discipline and don't get sloppy as you go (harder than you might think after the first few panels!). Then I follow up with a more normal foamgun/mitt technique.
The idea (as I'm always saying) is to dislodge the dirt with the least pressure necessary and then flush it away with the foam. The BHB will barely get any dirt on it, your rinse bucket will be almost dirt-free at the end of washing a very dirty large vehicle.
Yeah, this takes a very long time and you have to be very careful every second (literally every *second*). Watch for gritty dirt and take extra care with those areas. Stop and rinse the panel frequently and inspect your progress.
If any dirt doesn't come off, use a very mild clay like the
Sonus Green to remove it. Be careful doing this, you don't want to drag grit across the panel once it's stuck in the clay. Sometimes you have to do one swipe with the clay, knead it, then a second swipe, knead it, etc.
It might take ten minutes to clean one panel, sometimes even longer. Still beats having to polish and redo the LSP.
