Originally Posted by Alfisti Which "info" is that? |
"Many years ago brass was the common foundation for chrome."
Brass was never a common substrate. Copper and nickel were, and still are.
"the economy-box era ushered in chrome over steel"
This short-cut process was the original method of chrome plating. It's been in use for as long a chrome plating has existed. It's been the bane of cheap replacement bumpers for as long as there have been chrome bumpers.
"Today chrome over plastic (metalised plastic) is the common fare"
It was common half a century ago. It wasn't chrome then, and still isn't. There is no similarity between chrome paint or powder coating and electroplating.
"Chrome is porous and needs oxygen to retain its silver bright appearance."
Chrome is not porous, and does not need oxygen to retain it's brightness. Quite the opposite in fact, as oxidation does not shine, it's inherently dull. Oxidation of why chrome gets dull and needs polishing.
"When we 'think' chrome is pitting it is actually pulling away from its substrate"
No, that's peeling. Pitting is exactly that, as can be observed under magnification. It is frequently the result of poor plating or mechanical damage. Exasurbated by oxidation. Rusting of the base metal (steel being the most common) can then lead to peeling.
"CHROME IS EASILY DAMAGED BY ABRASIVES AND AMMONIATED SOLVENTS."
Chrome is a hard, inert metal. It is specifically used in situations due to its inherent a bility to resist abrasives. It is non reactive to solvents, including ammonia based ones. Zymol may have come up with this one from an incomplete understanding of chrome plating, where ammonia sollutions are used in some of the plating steps.
"WAX WILL TRAP MOISTURE IN THE POROUS CHROME SURFACE AND CAUSE THE SUBSTRATE TO CORRODE."
Only if you wax in the rain. Otherwise, waxes and sealants block water.
